Turbonetics vs Precision
suppp guys, so I'm having a little confusion about either getting turbonetics or precision turbo.. which one would be best for a tc that wants to make mid 300's hp and as a daily driver. Please I need help because me and my buddy are doing the same work to our tc's and dont know which to pick.
P.S- same size turbo as well.
X2 Brett nicely wrapped turbo looks awesome. Personally I run Precision products but the only factor you need to consider is Ball-Bearing or Non-Ball Bearing. Ball-Bearings perform stronger,spool faster, consume less oil over the life of the turbo but they have to be sent to manufacture for service if leaks or worn wheels occur. Non Ball-Bearing still get the job done and you can buy the rebuild kit and overhaul the turbo yourself. Hope this helps, either company is top-notch but it's up to you and your friend what you want and can afford.
Custom GTK 550... Never had a problem with it at all, I personally believe that you can't beat Turbonetics Ball Bearing Turbos and i've built numerous turbo projects with various turbos and like i said i dont think you can beat turbonetics all around.
i really cant wait to drive mine boosted. i drove it a couple days ago built on low comp pistons and cams and its pretty doggy. i will post pics once i get all my ic piping welded up and painted. how was your spool time?
SloTC1
08-16-2018 02:45 PM
Subaru86
07-31-2015 04:00 AM
MysTiKchRis
136
12-28-2007 12:54 AM
scionspecialistvegas
11-09-2003 08:18 PM
