Turbotoyotas TC turbo kits. Not in business no more!
Old 05-10-2007, 06:20 PM
  #181
mattieg's Avatar
Thanks Todd I think I will run the stage 2 at a low PSI level until i save up more money for rods and pistons. Im not looking for much. 350 hp is more than enough for me. But rods and pistons would put my mind at ease.
mattieg is offline
Old 05-10-2007, 07:46 PM
  #182
2_much_tc's Avatar
Originally Posted by TurboToyotas
todd, does this go for the bushing turbo too? i would like to be at or around the 330-350 numbers. what would be the best setup for that? what PSI would the kit be running at?
I could utilize a similar spec bushing turbo and get the same numbers, so yes. The only difference being the slower spool time with the busing resulting in the powerband shifting about 500-800rpms higher.(say 3000-vs 3500-3800 start point for conversations sake)
for 330-350 up top how low would you like the power to come on at? do you want to run a bushing setup or a ball bearing?
boost (psi) levels will depend on the turbo you run. But figure in the 9-12 range
hope that helps.
Regards-
Todd
thanks for the input todd. well, i dont mind running the bushing turbo, i just figured since you were still looking for people to run that one, I would go for it. i would like the power to be... say at the 3000 rpm range. but i like the fact that the ball bearing has quicker spool times.
im a confused guy...
2_much_tc is offline
Old 05-11-2007, 05:48 AM
  #183
Mr_Meaty's Avatar
the ball bearing turbo is the one that woudl come on at like 3000. The bushing would come on later, at like 3500-3800, right?
Mr_Meaty is offline
Old 05-11-2007, 06:14 AM
  #184
VitViper's Avatar
I sure hope not. My ZX2 has a bushing turbo and it sees boost before 3k... on a 2.0L.
VitViper is offline
Old 05-11-2007, 01:22 PM
  #185
Dyltone's Avatar
I'm sure you do see boost at low RPM's, but that probably means you have a pretty small turbo... Am I right?
Dyltone is offline
Old 05-11-2007, 02:15 PM
  #186
VitViper's Avatar
Did you not read my sig? I have a t3 t04e 57 trim .63 a/r. I wouldn't call that a small turbo. I said it sees boost before 3k, didn't mean it sees FULL boost before 3k (around 3100 it sees full boost, it starts making it around 2700-2800).
VitViper is offline
Old 05-11-2007, 02:19 PM
  #187
Team No Limitz
Simplyscion's Avatar
Im sorry but id hafta say thats a small turbo...not tiny like a 16g but its small
Simplyscion is offline
Old 05-11-2007, 02:20 PM
  #188
VitViper's Avatar
I guess it's all relative. Compared to something you'd slap onto a built Supra... sure. For this motor it is a large turbo.
VitViper is offline
Old 05-11-2007, 02:23 PM
  #189
Team No Limitz
if its efficient for your motor than thats all that matters
Old 05-11-2007, 02:24 PM
  #190
VitViper's Avatar
Works wonders for my little 2.0
VitViper is offline
Old 05-11-2007, 04:41 PM
  #191
Mr_Meaty's Avatar
well, i'm not sure if todd is talking about peek boost, or when it comes in, but i'm pretty sure the bearing turbo comes in quicker on both. There is less friction with bearings then bushings, so they spin better. And I believe Todd's turbo is one of the larger ones put on the tC.
Mr_Meaty is offline
Old 05-11-2007, 11:39 PM
  #192
TurboToyotas's Avatar
I picked those numbers as an example, but yes, the ball bearing would spool faster and come on quicker.
But what style manifold do you have? keep in mind I am not using a log style manifold. apples to apples remember
Not talking about what rpm it reaches full boost, but when it starts to spool and make positive pressure. Ball bearing turbos will always spool quicker regadless of the manifold style. (when compared to an equal spec'd bushing turbo)
The Stage 2 kit is based on a GT3071R which is just a bit bigger than most of the T3/T4's that everyone is used too.....but it's still not big. But for those who want something smaller and a killer powerband and want to make 310-340 whp(9-11psi) the stage 1 kit based on the GT28RS is the way to go But I have something for everyone.
Regards-
Todd
TurboToyotas is offline
Old 05-11-2007, 11:44 PM
  #193
Brett's Avatar
dont worry. there will be a bushing unit dyno on here real soon for people to compare to bb.
Brett is offline
Old 05-13-2007, 03:59 PM
  #194
mattieg's Avatar
What about new injectors for the turbo kit? How big can we go? Also what kind of engine management do you recoment? I want this to be the kit that goes on my car. Just want to make sure my car can handle all that power.
mattieg is offline
Old 05-14-2007, 04:18 PM
  #195
Depends on the turbo and how high you want to boost, but for example I am using 440's with the GT28RS kit and 650's with the 3071 kit. The 650's are overkill for how its curretly running but the customer only wanted to have to buy 1 set of injectors. This way he has plenty of room for growth.
Also what kind of engine management do you recomend?
Perfect world recommendation would be any STANDALONE.. ie AEM, Hydra etc.
But most go with Emanage. All but 3 of my customers have gone with the standard Emanage and added the pressure sensor. It works and is allot more affordable than the standalone options.
Regards-
Todd
Old 05-14-2007, 04:34 PM
  #196
Dyltone's Avatar
Affordable in the beginning... sure... long run... I vote standalone.
Dyltone is offline
Old 05-14-2007, 05:26 PM
  #197
griff's Avatar
how much are we looking at for the emanage kit ??
griff is offline
Old 05-14-2007, 06:15 PM
  #198
malloynx's Avatar
you using 440's to push 300whp?
malloynx is offline
Old 05-14-2007, 08:13 PM
  #199
Depends on who you purchase it from. I usually offer it as a package when you buy a kit from me.
yes, over 300 actually. With plenty of room for more.
Regards-
Todd
Old 05-16-2007, 06:48 AM
  #200
olaHalo's Avatar
what size injectors does the Stage 1 GT Turbo Kit come with, if any.
or do you not really have kits. do you just sell whatever setup the customer wants? Like are all your kits custom kits? (if so thats great)
and other than "silver turtle", who else on this forum is using your kits right now?
olaHalo is offline
Quick Reply: Turbotoyotas TC turbo kits. Not in business no more!
