Turbotoyotas TX Style!! broked axle!
Old 06-04-2008, 11:54 AM
  #301
Music City Scions
rhythmnsmoke's Avatar
Originally Posted by Mr_Meaty
...my numbers were with a stock midpipe...
and I had posted before about 17afr at idle or cruize and i got HELLA flack about it. NOT ONE PERSONE thought that was a good idea.
My tune has changed since the turbo and turning up the boost a little. It sucks right now, but my A/F ratio when cruising is in the mid 15's now. It use to be 14.8 - 15.2. Now it doesn't dip below 15.2 at all when I'm in cruise.
rhythmnsmoke is offline
Old 06-04-2008, 08:43 PM
  #302
mikescion's Avatar
Originally Posted by Ace83
It reminds me off playingwithfire's setup gt3076r with the twin scroll when he got low #s too but he got it retuned better, tune was conservative and afrs are around 10.9-11.3 which he recommends for the high tx heat.. Water temp are high too, close to overheating, fkn hot in there like an oven..
Makes me wonder if Todds new design of the manifolds are hurting the performance.....hmmmm Java what manifold are you running? I know that meaty is still on the peakboost manifold so thats another reason why he made more power too.
mikescion is offline
Old 06-04-2008, 09:13 PM
  #303
java09's Avatar
I'm still on the version 1 manifold.. Same as phils.. But I have a street tune!
java09 is offline
Old 06-04-2008, 09:20 PM
  #304
crush02342002's Avatar
vid on the way
crush02342002 is offline
Old 06-04-2008, 09:27 PM
  #305
Old 06-04-2008, 09:41 PM
  #306
Old 06-04-2008, 09:45 PM
  #307
mikescion's Avatar
That just adds to my thoughts that the manifold might be an issue because you and phil are on the peakboost manifold and making more or better power numbers then people on the other style manifolds. which that would really suck for alot of people including myself.
Old 06-04-2008, 11:02 PM
  #308
Ronin Scion
Ace83's Avatar
^^ you have or getting the 2.1 too? I havent really heard of new numbers from 2.1 mani.. but i have to figure out some issues first. Im getting an updated map too
Ace83 is offline
Old 06-04-2008, 11:04 PM
  #309
Ronin Scion
Ace83's Avatar
Oh yeah does anybody know if the hydra gets hot after driving, i was checking the placement after a drive and it was so hot like its even hard to touch.. If thats not normal the hydra could be the cause
Ace83 is offline
Old 06-04-2008, 11:06 PM
  #310
Ronin Scion
Ace83's Avatar
Originally Posted by crush02342002
vid on the way
thanks for the vids chris, this should be better.
Ace83 is offline
Old 06-04-2008, 11:17 PM
  #311
java09's Avatar
my emanage gets little hot.. as most electronics do.. does it have a cooling fan?? you know like car stereos.. its just a little pull fan.. laptops have them..
but yeah im getting the new version 2.1 mani soon so maybe ill dyno with the 2.1 without changing the tune and see if i make less power???
java09 is offline
Old 06-05-2008, 12:42 AM
  #312
vid on the way
not a prob, I got a couple more but it just takes too long to load
Old 06-05-2008, 02:28 AM
  #313
coryjames's Avatar
load them its worth it lol and cause we would all like to see more lol
coryjames is offline
Old 06-05-2008, 04:14 AM
  #314
Music City Scions
These are Mustang dyno numbers?
Old 06-05-2008, 04:25 AM
  #315
TurboToyotas's Avatar
The manifold has NOTHING to do with it.....NOT at all.
The new manifold out performs the olds style manifold across the board.
Its all in the tuning.
Even though Brandon has the old mani, his numbers are low, his tune is not anywhere near what it needs to be.
Ace is another victim of a bad tune, regardless of how hot it was....2 summers ago in the AZ heat over 110 I was getting 330 and 365 out of a smaller turbo(2.5dp and s-pipe) with the same ic on an Emanage.
This is the downside of the turbo business.....no manufacturer has any control after we ship the product....yet if something goes wrong or not up to expectations we are the first to get blamed. Yet we are not the ones hitting the keys on the keyboard when the most important part of a turbo kit is finaly put together.
Again its not the parts...........its the tuning, regardless of the dyno.
Again, go to the best Tuner you have in your state(one of the best in the country)...Tony at T1
yes he is $$$ but its money well spent and it will be right the first time
Regards-
Todd
TurboToyotas is offline
Old 06-05-2008, 04:27 AM
  #316
aen
aen's Avatar
tooooooddddddddd.
tune my car when i get to arizona so i can stop shi ttin bricks.
aen is offline
Old 06-05-2008, 04:47 AM
  #317
tooooooddddddddd.
I can arrange that for you. Its not me, as I am not a "tuner" but I have ones that will take good care of you.
Regards-
Todd
Old 06-05-2008, 04:50 AM
  #318
mikescion's Avatar
also he is on a 3076r on only 8psi that can't be effient there... well another thing you can do Ace is Download your tune to your laptop and e-mail it to other hydra tuners and get there insight. And todd you being the guy that knows alot about turbos should also know that 8psi isn't going to shine on that turbo. So i would think about all the facts before bashing ones tuning. And not to go against your gudgement on your manifolds but all the numbers so far show that your 1st manifold out performs this manifold at least on Low PSI....
Old 06-05-2008, 04:58 AM
  #319
Its not, but it can be allot better than what is represented.
There is enough info presented that allows me to "bash".
yes and no , but as most see it (as you do) on this site...I will agree with that. But its wrong...and that will change with time and as more who get this setup and post.
How many with the 2.1 have posted? And of those how many have the same turbo? not enough to make that kind of comment. But its ok.
Again...Tuning is the most important part of the equation, no matter how good or how bad the quality of the turbo components are.
Regards-
Todd
Old 06-05-2008, 10:32 AM
  #320
Regards-
Todd
I think ace was having problems with contacting T1.......
Hey ace refresh my memory what happened with them
Quick Reply: Turbotoyotas TX Style!! broked axle!
