Turbotoyotas TX Style!! broked axle!
#562
i have 3 permacool fans, but its the combination mishimoto radiator that did huge difference.. the ones from todd are fine though just add a 3rd fan and a thicker radiator w/ low temp thermostat and its gonna be great, you wont get heatsoaked or lose your ac.. just drove the car on 103F weather for like a day and i never overheated like before and thats with a bad exhaust leak blowing exhaust on the rad lol
#564
Originally Posted by jsg93085
which permacool fans are you using? ive already got a mishimoto radiator, but i think i still have the stock thermostat...
also what line did you tap for your vacuum block?
i say get a thermostat, its only like 20 bucks but works great..
here's what im using
2 of these in front
http://store.summitracing.com/partde...5&autoview=sku
1 of this at the back
and oh i should get a gift card from summit since ive recommended this to several people lol..
#569
Originally Posted by Ace83
im ordering copper gasket for my downpipe, i just found like a huge exhaust leak on my downpipe flange and its blowing hot exhaust on my radiator.. that might be the reason when i drive the car for a long time on the city my coolant temp goes to like 190-200F when normally its just around 175 to 186.. still working on the polished valve cover and im ordering my 2 step and flat shifting monday
the steps i took to do mine went like this
1. 400 grit (to even out the surface and flaten some slight bumps and pits)
2. 600 grit
3. 2000 grit
4. turtle wax brand rubbing compound applied 2 times(terry cloth on, micro fiber off)
5. turtle wax polishing compound (micro fiber)
6. clear engine enamel (havnt done it yet but will when i get time and gasket)
#571
i bought way tons grit here.. ill try prolly 400, 600, 1000, 2000.. and yeah the valve cover where i left off isnt shiney anymore its like smooth flat silver lol,, what kind of clear engine enamel did you buy? is that a spray can?
#573
gotcha, i think already know what it looks like in mind..
oh ps i would suggest on the 2000 grit to wet sand with it and be gentle since its the last major sanding, it will make the polishing go alot smoother.
#575
i finally completed polishing.. well not really but i gave up and decided not to be a perfectionist lol but its all mirror finish now just some finishing touches and some clear coat!
#580
Originally Posted by aen
dont' clear it, no clear is going to withstand the heat if you want it shiny just ceramic coat it
