Turbotoyotas TX Style!! broked axle!
#41
hahaha,
Ace and ZPI sitting in a tree, k-i-s-s-i-n-g, first comes love then comes marriage, then comes the bay in the baby carriage..
ZPI LOVER... traitor! baaaahahhahahahaaaaaaaaaaaaaaa
#44
Originally Posted by java09
hahaha,
remember houston is sea level, temp im sure is pretty much like hawaii haha
#46
yeah but that my last choice, got to check out this fastlane that 05rs1 recommend.. ima try another map today see how it goes.. java you're already using the truboost boost controller right? are you getting boost creeps? i havent hooked my boost solenoid yet so im boosting though my 5.9 wastegate spring but after checking my peakboost it goes as high as 7.8 psi where i only expect 6.. hmmm i wonder what is causing it
#47
same happened with me its not uncommon. I dont get any boost creep I'm boosting usually around 8 psi it goes as low as 7.5 and as high as 8.9.. My tunes defiantly jacked though becuase when at wot full boost my boost pressure is inconsistent. Its all over the place! But once I get higher in rpms it kinda levels out around 8. Which could and probably is the reason my torque numbers are so low...
#49
I have a vac Line that runs from the bottom port to the boost solinoid then the other end of that runs back into my top port vac line going to my vac block.. So its kinda like I tapped into the vac line that comes from the top port. Make sense? I get some build up but it takes a while till you can notice it.. It comes right off though!
#53
Originally Posted by tC_2NeR
n00b question. But, How do you Tee into an oil line?
Wouldnt the oil go squirting everywhere.
Cause I saw his photo of the transmission oil line,
Its a waterline for the watercooled turbo, those are coolant lines just an awesome steel braided hoses..
#54
well...i finally made it by! that new mani looks lovely!
So, if it take me being off the boards for another "TT Style" thead to pop up, I'll stay off more often!
Oh, and it's nice to see it only took Java to the second page to get this thread off topic, talking about his lack of tuners in Hawaii!
#57
yeah, been busy at work...
no, the first page pics are great! good detail. LOVING the new mani more and more!
And it looks like you got the newer IC pipes as well...could you take some pics of the ground clearance on them?
