Turbotoyotas TX Style!! broked axle!
Old 04-05-2009, 11:32 PM
  #581
Ronin Scion
Ace83's Avatar
yeah im not going to clear it lol it will just get it messed up
Ace83 is offline
Old 04-05-2009, 11:34 PM
  #582
crush02342002's Avatar
ace the polish looks effing great mang....good job bro
crush02342002 is offline
Old 04-05-2009, 11:37 PM
  #583
if you dont coat it it will oxidize...youll have to polish it up every week to maintain it...trust me...well then again its a little dryer where your at isnt it ace? i give it two weeks then....lol
Old 04-06-2009, 01:44 PM
  #584
Ronin Scion
Ace83's Avatar
^^ so should i go ahead and clear coat it? what should i use? i though the clear engine enamel didnt work out good
Ace83 is offline
Old 04-06-2009, 02:14 PM
  #585
on my engine cover it turned a slight yellow, iv used it on my nissan valve cover and didnt have any problems with it...the only diff is on the nissan i had a base coat of red engine enamel and a second coat of clear....i wonder if i didnt apply enough coats on it....if it doesnt work out it can be cleaned off with turpentine.
Old 05-14-2009, 12:35 AM
  #586
Ronin Scion
Ace83's Avatar
So im making progress on modifying my stock heatshield to work with my setup.. all i need now is to figure out how to mount it..
Ace83 is offline
Old 05-14-2009, 01:43 AM
  #587
so hows the polish on the valve cover holding up...lol...every time it rains mine gets totally effed...lol
nice idea bro on the heat shield...polish it...lmao
Old 05-14-2009, 01:48 AM
  #588
Ronin Scion
Ace83's Avatar
polish is still there not as shiney.. i would definetely polish the heatshield lol, its not as bad as the valve cover.. but hey how bout some ideas how to mount the heatshield?
Ace83 is offline
Old 05-14-2009, 01:51 AM
  #589
all4degame's Avatar
zip ties! hahaha
all4degame is offline
Old 05-14-2009, 01:55 AM
  #590
Originally Posted by all4degame
zip ties! hahaha
all hail zip ties
prolly need to weld some nuts to the mani and use short bolts to bolt the shield to the mani...
Old 05-14-2009, 07:02 AM
  #591
Ronin Scion
Ace83's Avatar
haha i like the bolts on the mani idea, it just wont make the mani as pretty.. i want something that easily gets removed for beauty contests bahahahaha.. im thinking of a bracket i can attach using the bolts on the valve cover
Ace83 is offline
Old 05-14-2009, 10:51 AM
  #592
well then ther ya go...prolly want to weld two tabs up top that will bolt onto the manifold head studs...problem is the head studs arent that long and youll need to replace em with longer ones...on the bottom side you could weld on a large wormdrive clamp and just clamp it around the turbo to mani flange...or again you could weld tabs that will bolt onto the turbo to mani flange...and of course again youll need longer bolts...
Old 05-14-2009, 10:52 AM
  #593
ahh valve cover...need to read closer...lol
Old 05-14-2009, 10:53 AM
  #594
duct tape works too....lmao....
Old 05-30-2009, 06:33 AM
  #595
Ronin Scion
Ace83's Avatar
So went to the race track today.. my times sucked but it was fun doing tuning one each run until my right axle broked
Main problem with my runs was on launch, my launch control settings needs to be tweaked, i keep stalling if i throttle too much... then my all summer tire that almost looks like slicks kept me spinning in place lol.. tweaked my tune on each run, the best launch on my 4th run but my axle popped sfhiting to second.. it just calls me to get built ones.. but i need cheap ones for now
pics to come soon
Ace83 is offline
Old 05-30-2009, 12:51 PM
  #596
Skeeeett's Avatar
damn that suxx srry to hear......
but on the other note what you could do is try to make brackets from the valve cover bolts to the heat shield(the 3 bolts on the valve cover) maybe you can make some custom brackets(kinda like L brackets) from those and drill them onto the heat shield..but make it all pretty lol ...idk just throwing u some ideas
and u can paint it the 2000 degrees engine paint(flat black)
Skeeeett is offline
Old 05-30-2009, 01:40 PM
  #597
pics to come soon
idk ace i havnt broken an axle yet, im sure if you can i will soon enough
Old 05-30-2009, 02:00 PM
  #598
Ronin Scion
Ace83's Avatar
I need something stronger than the oem ones lol.. i wasnt even on slicks lol.. the pop was scary though, revved it like 3 times and the engine sounds good w/ good oil pressure i know then it was an axle
Ace83 is offline
Old 05-30-2009, 02:02 PM
  #599
B_Real45's Avatar
That sucks, mang. The worst part about turbo'ing NA FWD cars is the freakin axles going.
B_Real45 is offline
Old 05-30-2009, 06:58 PM
  #600
jwaggz82's Avatar
what page does the axle break info start?
jwaggz82 is offline
Quick Reply: Turbotoyotas TX Style!! broked axle!
