Turbotoyotas TX Style!! broked axle!
Old 04-04-2008, 02:03 AM
  #61
java09's Avatar
my dezod exhaust is close to my bumper but doesnt touch.. midas also welded and re angled my exhaust so its centered and not touching!
java09 is offline
Old 04-04-2008, 02:18 AM
  #62
Ronin Scion
Ace83's Avatar
yeah but the dezod uses the other hanger on the driver's side rear the tsudo doesnt that's why no matter how long the hanger is still hit the bumper unless there is a support that keeps it from moving.. the support is welded straight from the car and with little movements after sometime the weld would become weak
Ace83 is offline
Old 04-04-2008, 02:19 AM
  #63
java09's Avatar
ahhh i see.. well that sucks! yo did you see that LSD for 1052.50 from dezod.. i think im getting that!
java09 is offline
Old 04-04-2008, 02:20 AM
  #64
Ronin Scion
Ace83's Avatar
yeah saw the post not the price yet, not sure yet though.. and that includes the install accessories right?
Ace83 is offline
Old 04-04-2008, 02:40 AM
  #65
java09's Avatar
im thinking so.. that would be excellent! i need that ****!
java09 is offline
Old 04-11-2008, 04:07 AM
  #66
Ronin Scion
Ace83's Avatar
So finally got the scan gauge in, first of all its awesome.. absolutely a great buy, thanks to 365motorwerks! Then I got my these codes
P0303- Cylinder #3 misfire
P0171- System too lean (bank 1)
P0302- Cylinder #2 misfire
P0000- ?? didnt find it but after a search is Powerstroke with no power?
I just found the meanings through google but all codes should be universal right?
The scan gauge said 5 codes detected but it only showed 4, does it mean one of the code prolly happened twice?
you guys have thrown these codes before?
Ace83 is offline
Old 04-11-2008, 04:24 AM
  #67
tC_2NeR's Avatar
why would you be misfiring tho?
i dont understand
ur not tuned right ace?
tC_2NeR is offline
Old 04-11-2008, 04:30 AM
  #68
Ronin Scion
Ace83's Avatar
nope not yet tuned.. these are the second set of codes from the install using a map to get it running, the first set was cleared without being checked but that should be way more crazy (running emanage without a map haha)
Ace83 is offline
Old 04-11-2008, 04:39 AM
  #69
java09's Avatar
if it said 5 and only showed 4 that means since the last time you started your car the ECU or the what not has since corrected the issue.. not sure about the mis firing but i got that lean fuel back 1 code p0171 before i wasnt tuned and havent gotten it since.. the only one i get occasionally is p0101, MAF performance.. nothing major.. i just clear it..
java09 is offline
Old 04-11-2008, 04:48 AM
  #70
Ronin Scion
Ace83's Avatar
so that means of the 5 code i had? 4 hasnt been corrected? If you disconnect the battery, old codes will not be retrieved right?
anyone had misfire?
Ace83 is offline
Old 04-11-2008, 05:35 AM
  #71
java09's Avatar
ive never had misfires and yes taking the neg of the battery for 15 secs and you will have no codes but once you start the car they will be right back...
java09 is offline
Old 04-11-2008, 05:38 AM
  #72
Ronin Scion
Ace83's Avatar
i still dont get why i only found 4 instead of 5 codes, can you explain it further?
Ace83 is offline
Old 04-11-2008, 06:00 AM
  #73
Mr_Meaty's Avatar
i've had all those codes before. all went away after a different map, but I thought my misfires were from fouled pluggs.
If you had a repeating code, it would come up twice. not sure about the readign 5 and showing 4, but if you clear all codes and then clear them again with the scangauge, it should actually clear all of them so you can start from scratch.
Mr_Meaty is offline
Old 04-11-2008, 06:05 AM
  #74
Ronin Scion
Ace83's Avatar
yeah im gonna see how long they will come back, i might have foul plugs too from running super rich before i loaded the map.. you have any idea of any fatal/dangerous codes we should watch out for?
Ace83 is offline
Old 04-11-2008, 06:06 AM
  #75
java09's Avatar
haha a lot of codes can be fatal to your motor.. mis fire bad enough and you will have mucho issues..
java09 is offline
Old 04-13-2008, 01:22 PM
  #76
Ronin Scion
Ace83's Avatar
ok i just got another P0171, but my WOT AFRs are fine though, its in the low 11s, i think its my idle that is lean or maybe my partial throttle.. i'll try to adjust timing and see if it helps
Ace83 is offline
Old 04-13-2008, 02:03 PM
  #77
HyPn0TiC's Avatar
Ace, I'm hoping you arent running too much untuned. I was misfiring as well and it caused my blown motor. Untuned=BAD!!!! Dont go into boost at all until you have a tune on your car. I'm just warning you man. I dont want you to have to go through what I'm going through right now. Sucks being without a car. I am driving around an RX-8 right now though. Once I get my car back it should rip though. Pistons, rods, bearings, and probably sleeved. Then I'll be building my head over the summer and then I'll have a quick lil car. LOL. Good luck man. Looks great so far though.
HyPn0TiC is offline
Old 04-13-2008, 02:17 PM
  #78
Ronin Scion
Ace83's Avatar
yea not really getting on it, if not few seconds.. what happened to you motor by the way? keeping my eyes on afrs though, and still waiting on oil restirctor so i cant really drive agressive coz i might blow my turbo seals..
Ace83 is offline
Old 04-13-2008, 04:49 PM
  #79
HyPn0TiC's Avatar
my cylinders were misfiring. AFR was good the whole time too. After draining the fluids it seems that from the spark plug hole you can see the crankshaft if #1 cylinder. So apparently the misfiring wore down my piston and no the piston and rod are both gone. shattered. Fun stuff man. Hope you dont have the same issues. Again, good luck man. Avoid driving much. And dont build boost at all. Because that what I did. I built boost just a few times and then boom.
HyPn0TiC is offline
Old 04-13-2008, 07:35 PM
  #80
Ronin Scion
Ace83's Avatar
are you misfiring a lot? im daily driving my car and im gonna see if im gonna see more of the codes i had first time i checked it but so far its only P0171 that came back. My tuner is like 6-7hrs away from here so I at least should run a decent map on the way. I hope nothing bad is gonna happen to mine though. If codes keep coming then im gonna have to find a fix on that first before i can tune. And which map are you using?
Ace83 is offline
Quick Reply: Turbotoyotas TX Style!! broked axle!
