Uh-Oh?
Old 05-24-2008, 11:50 AM
20tCDude05's Avatar
Default Uh-Oh?
Well my friends, looks like something blew up. I mean, seriously, I was driving on the interstate and some smoke blew in through the center air vents and felt a lag in power, then the power came back, so figured it was nothing, but still wanted to check when I got back with my group. When I got back, I checked under the hood and there was oil everywhere. On the turbo, under the turbo, on the valve cover, on the block, even under the hood. So, I am pretty sure something blew up. The interesting thing is that I was changing my oil the night before and noticed some dirt covered oil on the pan, meaning its been like that for quite awhile, so figured it was pretty small. Also, my friend with an Evolution whom he is buidling said SAME thing happened to him and it totally f*cked everything up, spun the bearings, etc. So, he is thinking the same thing is happening to me. The best thing about this is that I have a sleeved motor, built head (supposedly), and custom cams (supposedly) from 318_tC and rods, valve kit from Dezod, main and rod bearings, head gasket from Cometic. I think that is about it. I just need pistons. But, yea, I basically have a back up plan, so looks like I may need to skip to a Stage 2.5 of my plans. Because I cant afford a standalone as I gotta get pistons, piston parts, motor built, port and polish the head, etc. So, thinking going for 400WHP for starters. Any ideas on what the problem is? And no bantering about my "rampage" because I was having a terrible night relating to family health. But, yea, hope you have suggestions or ideas.
20tCDude05 is offline
Old 05-24-2008, 12:53 PM
B_Real45's Avatar
That's all very hard to say, bro..
Where was the oil coming from? You said it was on the turbo, under it, on valve cover.. find out where it came from.
I would wipe down the whole engine bay and run the car to see where it's coming from. It could be something as minor as a valve cover gasket.
Take some pics
B_Real45 is offline
Old 05-24-2008, 03:59 PM
Guru's Avatar
If you had a hole in your block your car wouldn't be moving. and you wouldn't have any oil left in your pan either. Sounds to me like you burst a leak on your oil feed line somewhere. Hard to say but yes clean everything thoroughly and start up car to see where the oil is coming from.
Guru is offline
Old 05-24-2008, 06:39 PM
stockturbo15's Avatar
if your car was still running it sounds like something simple aka not that serious
check it out.. take pics.. im sure we can help out. Clean it off and find the leak.. find the highest point you can see oil
stockturbo15 is offline
Old 05-24-2008, 07:04 PM
BrownDogg's Avatar
What they said.... It sounds to me like you blew an oil feed line because if you spun a bearing or blew something up the motor would have seized up and shut off. Does the car still turn on and start? If it does then you didnt blow your motor.
Were you under boost when the smoke happened?
BrownDogg is offline
Old 05-24-2008, 07:53 PM
2_much_tc's Avatar
i gotta suggestion, stop being a d!ck in everyone else's threads...
2_much_tc is offline
Old 05-24-2008, 08:40 PM
crush02342002's Avatar
hahaha...nice
crush02342002 is offline
Old 05-24-2008, 11:17 PM
Syldrin's Avatar
Wait wait wait captain neons blew something up? lawlz!
Syldrin is offline
Old 05-24-2008, 11:31 PM
20tCDude05's Avatar
Actually, I didn't because I can still boost. But, it does sound different. Oh well, I will be faster than Garabaldy sooner than later apparently. Boy, I loved it when you were absent.
Old 05-24-2008, 11:41 PM
Scoobasteve4132's Avatar
Are all your oil lines hooked up and good to go?...
Scoobasteve4132 is offline
Old 05-24-2008, 11:43 PM
20tCDude05's Avatar
Not sure, hard to see the one under the turbo, I think that is where it's coming from. Just not sure how the top of it, the charge piping next to the intake piping, BOV, valve cover, and the underside of the hood got oil on it. Plus, my A/C is not working, so...
Old 05-24-2008, 11:45 PM
Have you taken of the valve cover lately?
Old 05-24-2008, 11:49 PM
20tCDude05's Avatar
I meant the plastic valve cover, not the actual one under it.
Old 05-24-2008, 11:50 PM
B_Real45's Avatar
I'm tellin you - you won't find anything until you clean it up and look for the oil leak.
B_Real45 is offline
Old 05-24-2008, 11:52 PM
Can you shoot some pics?
Old 05-24-2008, 11:54 PM
20tCDude05's Avatar
Meh, not sure if pictures will help. It's just all over. I cleaned it up though. It might only leak during boost or something. I will get it checked soon though.
Old 05-24-2008, 11:58 PM
Yea, make sure everything's good and tight... Have you clocked your turbo recently?... Ive heard that can cause a mess if left loose...
20tCDude05's Avatar
Not sure how to "clock" a turbo.
Old 05-25-2008, 12:00 AM
hmm, got me..... good luck w/ finding it and getting everything back up 100%...
Old 05-25-2008, 01:35 AM
Strictly Scionized
redrumtc's Avatar
yea it sound like a oil line what kind of tape did u use on your lines man I had that same thing happen to me and it was just one of the lines that had came lose..
redrumtc is offline
