Understanding Max MAF Voltage/CFM
Old 03-22-2012 | 06:46 AM
ThatGuyAtGeweke's Avatar
Originally Posted by trd07tc
Well the ECU uses data from more than the MAF to determine duty cycle.
From my experience the MAF clamp function does not work well - the car just doesnt run good. If I use MAF adjustment the car runs a lot smoother. I wish it were as simple as clamping the MAF and just tuning injector and timing.
I dont know what the neo can or cant do because I have never used one
Unichip has maf clamping along with the timing / fuel changes needed. Well i did not need any timing adjustments. We have a VVT-i controller which controls timing. My timing stays at 8 to 15 deg. at 5psi 10psi 15psi and 18psi only thing we did was retard timing before boost built up 1000 to 3500 rpm to give us a little bit more lower end acceleration. Left the boost load alone.
Gigs
09-15-2015 04:54 AM
carid
08-31-2015 12:17 PM
carid
08-07-2015 12:32 PM
mw1957
07-28-2015 07:04 AM
mw1957
07-28-2015 06:31 AM
