USED TRD Supercharger install missing parts! Please Help!
I bought a used TRD Supercharger from a guy for $1500, and i am missing a few things. I wanted to know if the parts i am missing will cause any problems.
-I am missing the new crank pulley bolt (why do i need this is it stronger, b/c it cost about $170 from TRD) Can i use the OEM one, what problems will i encounter?
-Missing fuel line from TRD. Do i need this new line, or can i use the old one? what problems will i run into
-the small filter (trumpet) for the TRD airbox i am planning on using my Injen to modify it to use it instead. I have heard this will not really cause any air/fuel mixture problems.
-lastly i am using the NST pulley 9.5 with TRD reflash and it is an automatic, i already bought the Auto TRD fit kit for the tranny dipstick
Thanks for your help.
I just bought a s/c missing parts also, I got the thermostat fuel line and crank bolt from trdsparks for 172.50 shipped the crank bolt from them was 90. I am also cutting my injen cai to fit because I didnt get the stock airbox.
I would get the crank bolt it maybe be alot but if it snaps off in the crank that 90 won't seem like very much. As for the fuel line I'm not sure if it would get in the way of the charge pipe. The TRD reflash in a must.
Originally Posted by hellbird79
just to be sure, you guys are saying i dont really need the crank bolt or the fuel line? I can just use my stock ones and be ok?
Thanks!
Thanks!
ok guys here is what i am going to do. I am going to run the gates belt for the 9.5 NST pulley. Use the TRD airbox just in case i run lean with the CAI, trd reflash, trd injectros, use the trd pretapped oil pan, i am am missing a few things the spark plugs, and the thermostat. Does anyone know ngk plug part # i can use, the densos are discountinued. also anyone know a thermostat i can buy locally from autozone, i can buy? part number would be great. I am not going to use the crank bolt, nor the fuel line. Does anyone think this will be a problem?
just did some research, it seems everyone is using the ik24's for plugs on the s/c are these ok? They are pregapped right, so you just drop them in?
Also what thermostat should i use? or should i just order one from TRD?
Thanks
Thanks
not sure about the thermostat but the trd one is 71°C (160°F). maybe you can find a similar one. like i said, id replace them with trd, but let me know how the car runs with the stock fuel line and crank bolt.
Thanks
Thanks
just get the plugs and thermostate from the dealer. make the car run right.
good to hear. this will probably be a dumb question, but im too lazy to search. can you briefly explain to me what a gates belt is? i know the s/c comes with a serpentine belt. is this a replacement for this? thanks in advance.
TheTripleC
01-04-2015 06:46 PM
TRDSCIONTC06
12-31-2014 10:12 PM
