Walbro 255 LPH Fuel Pump
Team No Limitz
Originally Posted by deathbyc4
i want to see a diagram of how it was ran. inline after the stock pump or removed the stock, etc.
The standard walboro will not work with out modification in the tC. The 255 is longer than the stock pump wich makes it not fit into the assembly correctly. We have used these is a a lot of tC you will need to cut the stock plug and wire a plug in and modify the lower portion of the assembly to insure a secure fit...
