Walbro 255 LPH Fuel Pump
Old 09-27-2006, 11:02 PM
Team No Limitz
Simplyscion's Avatar
Originally Posted by Simplyscion
Originally Posted by deathbyc4
i want to see a diagram of how it was ran. inline after the stock pump or removed the stock, etc.
i removed the stock sending unit, removed the stock pump, wired in the stock harness clip into the new pump and modified the sending unit for it to fit...dropped back into the tank and walla
same for the xB
Simplyscion is offline
Old 09-28-2006, 03:56 AM
MN Scions
IndigoTC's Avatar
so is there an aftermarket pump made specifically for the tc?
IndigoTC is offline
Old 09-28-2006, 02:32 PM
Rasta's Avatar
Default Re: Walbro 255 LPH Fuel Pump
Originally Posted by 318_tC
This should work just fine for the tC shouldnt it?
I am running a walbro in tank pump with a return and no problems AFR's no higher than 11.8 or so.
Rasta is offline
Old 09-28-2006, 02:34 PM
Rasta's Avatar
I am using one for an IS300 you will need the IS300 bracket for it and a 1/4" ball bearing to plug the stock regulator.
Rasta is offline
Old 09-29-2006, 03:34 AM
ERIC-TC's Avatar
Anyone have info on how to raise the stock fuel pressure on the tC? Could in-line pumps be used? What about modifing the pressure regulator on the stock fuel-rail-line? Any pics of installs?
ERIC-TC is offline
Old 09-29-2006, 12:08 PM
Rasta's Avatar
I use the fuel pump and a Aeromotive regulator
Rasta is offline
Old 09-29-2006, 02:53 PM
ERIC-TC's Avatar
Do you have more details on your setup?
ERIC-TC is offline
Old 09-30-2006, 03:15 AM
influence's Avatar
Default problems with something
I just installed one in my TC have the Turbonetics kit. Had to modify a bracket on the bottom to hold the pump in and get a new plug (the Tc is too narrow) but now my car falls on its face a 3k-3500 and will not boost up. My A/F is 17-18 at idle too...anyone
influence is offline
Old 09-30-2006, 02:20 PM
ERIC-TC's Avatar
Did you modify your fuel rail with a fitting for the return-line? You will also need to remove the pulse-damper off the fuel rail and replace with a fuel pressure regulator. Hell might as well install one of those small fuel-pressure gauge at the rail as well.
ERIC-TC is offline
Old 07-07-2008, 05:51 PM
1UP Crew
ippskidder's Avatar
sooo..... to make the install easier for walbro fuel pump i'll have to get an is300 fuel pump bracket?
and the 1/4" ball bearing is incase I upgrade to an aeromotive fpr???
ippskidder is offline
steeze69
05-24-2021 02:57 AM
mudguy
10-22-2015 04:31 PM
MeDizzy
10-08-2015 03:31 PM
vi3tb0i09
09-23-2015 08:32 PM
paisatronix
09-05-2015 04:13 AM
Quick Reply: Walbro 255 LPH Fuel Pump
