Wastegate adjustment
Old 10-13-2006 | 03:39 PM
MilesMc214's Avatar
Default Wastegate adjustment
Does any one knowo the proper way to adjust a tial 38mm wastegate down to 6psi. It came with a .9 bar spring which is 13 psi and I dont want to run that on the stock motor. So is there anyway I can adjust this, or do I just simply have to buy a new spring.
Thanks, --Miles
Old 10-13-2006 | 05:40 PM
Prototype_xB's Avatar
Change the spring. Dezod's got you covered!
http://www.dezod.com/pd_tial_wastegate.cfm
They can get you an assortment of springs, from 3psi all the way up to 20psi for the 38mm tial.
Old 10-13-2006 | 05:56 PM
Joe_Dezod's Avatar
Thanks man!
Yes they make all different types of springs to get that bad boy set to run whatever you want. Make sure you either have a rubber padded C-clamp or another buddy helping you change it out.
Old 10-13-2006 | 08:04 PM
tc2nut4's Avatar
i can picture someone trying to hold that 20 psi spring in place and re-assemble the wastegate with their bare hands
Old 10-13-2006 | 08:08 PM
fusionscion's Avatar
Default Re: Wastegate adjustment
Thanks, --Miles
yes you have to change the spring... i believe it is blue for the levels you are looking for... there is a whole set of springs from low psi all the way up the the 15-20 psi levels...
Old 10-13-2006 | 09:17 PM
318_tC's Avatar
try and do it ur self with a 20psi spring...lmao!
Old 10-13-2006 | 09:31 PM
tc2nut4's Avatar
i'd pay to watch that
SloTC1
08-16-2018 03:45 PM
Darrenohooligan
09-26-2015 08:21 AM
vi3tb0i09
09-23-2015 09:32 PM
Subaru86
07-31-2015 05:33 AM
Subaru86
07-31-2015 05:00 AM
Quick Reply: Wastegate adjustment
