Weird Boost Problem*NEW PROBLEM*
So today i'm driving then all of a sudden BAM! CEL pops on
its code p0102 which means Mass Air Flow (MAF) Circuit Low Input. Im guessing that its more related to a Vac Leak rather than my MAF.
Anyone else have this code?
I'm going to install my TurboToyotas Vacuum block with all new hoses to make sure its not a VAC leak
EDIT**
I just installed my TT vac block and my CEL went away
EDIT**
Re: Weird Boost Problem*NEW PROBLEM*
NEW PROBLEM
So I thought my troubles were behind me but I guess not.
My car runs fine until I hit boost, and once I hit boost i Get code p0102 (MAF circuit low input) and the Throttle no longer works. My scanguage is hooked up and the Throttle position sensor reads perfectly fine. With the CEL on, I will go WOT and the TPS % increases but my car doesn't go anywhere, not until I downshift then the car will sputter along. Once I clear the code the car runs perfect, that is until I go into boost then it happens all over again.
I had an appointment this moring with my tuner, but wasnt able to make it because my car was running like poop. I also hear a click everytime i push the throttle
My question is, is my problem my MAF? I dont think its my throttle position sensor, since we have electronic throttles so i assume that the MAF code will affect my Throttle response.
I already cleaned the MAF with cleaner and reset the battery and it still does the same stuff. I just dont feel like spending $150 on a new MAF and it do nothing for me
Anyone have any clue?
that sounds like it could be a defective maf but in the end the dealership techs would be the one to tell you that.. i dont like taking my car to stealerships! Good Luck though man.
Originally Posted by aen
take engine management system off, start car on stock ECU.
if it starts fine...it's tune/management system
go from there
go from there
Any advice on the throttle making a clicking noise when I press the gas?
Most likely a defective maf but check for leaks especially after the maf, your car could be sucking air somewhere unmetered by the maf.. It may not be obvious when not in boost since the maf can still get some air but when the turbo builds boost, some of the air might be sucked somewhere not measured by the maf so the amount of air/boost going to the throttle doesnt coincide and is too high compared to the air that the maf has metered so you get a code, may not be the case but just a guess.
Haha nice, I needed a laugh. I wish my car had a face so I could punch it!
I hope I fix the problem fast, I have a show this saturday and it's 1 1/2 hours away, dont want to get stuck all the way out there
So tonight im going to go over every Vac line and coupler AGAIN, and clean my throttle body and check for anything loose that might be causing the tapping.
Originally Posted by Ace83
the tapping is a sign of something loose pay attention to where the tap is, it may not be your throttle
It only happens when I press the gas so it has to be something with the throttle body
I today I re-redid my Vac Lines (found my BOV line was pinched) , and Couplers (all was fine)
I also cleaned my throttle body (it was covered in Carbon Buildup)
I took the car out for a run and it ran like a Champ! No Cel, or clicks, or and boost surging.
I want to thank everyone for the help, I love my car when it runs this good, lol
crimson_sinn
09-25-2015 09:41 PM
gqdabien
09-17-2015 09:23 PM
ScionLife Editor
09-15-2015 04:40 AM
