Weirdness while under boost....question answered please lock
I noticed tonight that under boost (and not sure at what point but around 2-5 until 10psi) my brake light on the dash comes on then goes off when i let off. Has anyone seen that before?? I'm not a noob but that's just a little odd. Fuse inspection will happen tomorrow.
Also noticed that my scion securty (the glass break sensor) LED stays on when i lock the car and haven't noticed that before either.
Only recent change was resetting the ECU that previous night before after updating the map on my Dezod black box and reattaching a vacuum line to my fuel pressure regulator (was previously unhooked since i was mainly using the black box for riching the car.
Any knowledgeable help would kindly be appreciated!
as you move, the brake fluid shifts the shift messes with the sensor..it causes the light to come on momentarily and turn off, to the average consumer that woul cause them to bring it into a shop and get it "checked" when all it means is your pads are low
Originally Posted by deathbyc4
hmm, that's a good possibility. it's getting close to brake pad change time. any thoughts on the LED?
steeze69
05-24-2021 02:57 AM
gqdabien
09-17-2015 09:23 PM
BlingSlade
09-05-2015 08:52 AM
Armystrong
08-31-2015 08:19 PM
