Well guys, I ordered a Greddy Kit
Old 06-02-2006, 04:31 AM
  #241
PRacing_com's Avatar
The BOV is above the poitive (red) part of the battery in the picture.
Looks great man. I saw one yesterday, and that dude was FLYING, in a street race. Sounded NIICE.
PRacing_com is offline
Old 06-02-2006, 04:37 AM
  #242
Music City Scions
rhythmnsmoke's Avatar
Originally Posted by 1lowtc
Well guys, as you all know I completed my install last weekend. I haven't posted any pics bc I have had some issues with starting the car, and also driving the car. I bought the emanage support tool to see wtf was going on.... Come to find out my AAV's showed a 16% increase at 2k rpms, so I adjusted it back to 0 which is the default setting. I checked the rest of the main settings and they wedre correct, however when I checked the Air Flow and Ignition maps,... There was NOTHING! All the values were set to 0 which means the car is running the factory settings. I am not sure if greddy calls this there map or if they simply didnt export the software into my main unit on accident. I will be calling them tommorrow to investigate. I will keep everyone posted.
Is the Upper charge pipe curved, or is that just shadow in the picture?
rhythmnsmoke is offline
Old 06-02-2006, 06:10 AM
  #243
tcholic's Avatar
^shadow, mine is straight
tcholic is offline
Old 06-02-2006, 01:02 PM
  #244
Music City Scions
^^Ok, just wondering. Good job. If you posted already, sorry don't feel like going back, but what PSI did you say it was set to?
Old 06-02-2006, 03:50 PM
  #245
XD40tC's Avatar
Default Re: stupid question
Originally Posted by turdman
To anyone who has this kit installed--
Did you have to tap the oil pan yourself? Did you have to weld any pieces together? Any check engine lights? Did the kit come with installation instructions? What were all the extras to the kit that you bought seperate, and how much did they cost? And lastly, how long was the installation?
Sorry about all the questions. I'm looking at picking up this kit, and just wanted to clear up some things and do my homework.
Thanks
BTW: The kit looks nice!
Some of these are my questions as well. Thanks!
XD40tC is offline
Old 06-02-2006, 09:47 PM
  #246
r1mirostc's Avatar
jus curious...does any one know how high it revs with the greddy turbo kit???
r1mirostc is offline
Old 06-02-2006, 10:12 PM
  #247
Music City Scions
The same as every other N/A'ed/Turboed tC would. Rev's don't change, unless you tinker with it using something like Ultimate E-manage.
Old 06-03-2006, 04:31 PM
  #248
Mizle's Avatar
damn thats beautiful!!! now lets see those dyno numbers!
Mizle is offline
Old 06-03-2006, 06:49 PM
  #249
tcholic's Avatar
8.5 psi, but preset tuned maps suck, i would go get it tuned as soom as possible with a good tuner after installed
tcholic is offline
Old 06-04-2006, 02:50 PM
  #250
1lowtc's Avatar
8.5 psi, but preset tuned maps suck.
Ditto,... I am going to be street tuning my car today. The stock map boggs around 5k rpms,.... I am going to swap the 440cc injectors to 550cc also.
Anyways, here is an important tip for anyone going to use dezod's pnp harness with the greddy turbo kit. I have been working with Bennie @ greddy and Pual from Dezod to find out a cold start issue with the kit. After tinkering with it for weeks, I found the issue and solved the problem.
The greddy pretuned emanage comes with the rotary settings and jumpers preset. On the jumper JP2, greddy sets it at 1-2 which is correct if you use their splice in main/injector harness,.... However, if you use the dezod pnp harness, the jumper setting must be changed to 2-3. The dezod harness includes the ignition harness, which changes the greddy setting as they do not include the harness. The JP2 setting 1-2 =5v ignition output while the 2-3 =12v ignition output. Hope this helps others that encounter the same problem.
Jon
1lowtc is offline
Old 06-04-2006, 09:12 PM
  #251
Revilo's Avatar
Jon
What about if you use the Ultimate Package? Because the Ultimate Package says that it includes the Pre-Programmed E-Manage Ultimate w/ full harness set.
Revilo is offline
Old 06-04-2006, 11:09 PM
  #252
1lowtc's Avatar
The ultimate should be set to the harnesses greddy provides. The ultimate has many more jumpers than the emanage also, so I could not suggest the settings for it.
Jon
1lowtc is offline
Old 06-04-2006, 11:57 PM
  #253
Scionetics
KAD
paul_dezod's Avatar
Glad you got it running and we could be of assistance.
Pleasure to had spoken to ya.......Let me know if you need anymore help.
paul_dezod is offline
Old 06-05-2006, 12:12 AM
  #254
1lowtc's Avatar
I am going to be working on tuning,... Eventually I will be building a block and maybe heading your way for some serious tuning.
Jon
1lowtc is offline
Old 06-05-2006, 12:49 AM
  #255
Revilo's Avatar
buying the Ultimate Package with the Dezod PnP would be no Problem?
Revilo is offline
Old 06-05-2006, 01:10 AM
  #256
Scionetics
KAD
paul_dezod's Avatar
Jon
Ok. Lemme know.
  #257
1lowtc's Avatar
If you buy the ultimate pnp harness it shouldnt be an issue. Do note that the emanage and emanage ultimate are two different harnesses though.
Jon
1lowtc is offline
Old 06-05-2006, 01:11 AM
  #258
Scionetics
KAD
paul_dezod's Avatar
We have a harness for it, but we do not have a tC profile or jumper settings for the Ultinate to share. We have not ventured with this unit.
Old 06-05-2006, 01:16 AM
  #259
Revilo's Avatar
so the Ultimate has to be install "by the old way"? no PnP could be use for the GReddy Turbo Kit?
Revilo is offline
Old 06-05-2006, 01:19 AM
  #260
1lowtc's Avatar
Dezod sells the harness you need, Pual just stated it ;) You just need to get the jumper settings from greddy or just buy the option 2 pre-programmed upgrade.
Jon
1lowtc is offline
Quick Reply: Well guys, I ordered a Greddy Kit
