Well guys, I ordered a Greddy Kit
Old 06-05-2006, 01:20 AM
  #261
Scionetics
KAD
paul_dezod's Avatar
Originally Posted by Revilo
so the Ultimate has to be install "by the old way"? no PnP could be use for the GReddy Turbo Kit?
He used our PnP for the e-man blue and our jumper settings.
Our Ultimate PnP would work as long as you have the proper jumper and profile settings for the E-man U from someone or GReddy.
paul_dezod is offline
Old 06-05-2006, 01:30 AM
  #262
Revilo's Avatar
are you planning to make (or whatever) jumper settings for the Ultimate?
Revilo is offline
Old 06-05-2006, 07:02 AM
  #263
Scion Dynasty
Squishface's Avatar
Lookin good man. That manifold is gorgeous.
What turbo is on this kit?
Got anymore pics? Let us know some numbers as soon as u tune it. Good luck!
Squishface is offline
Old 06-05-2006, 01:14 PM
  #264
Scionetics
KAD
paul_dezod's Avatar
We make a harness for the Ultimate.
http://dezod.com/pd_dezod_motorsport...dy_emanage.cfm
Old 06-05-2006, 01:32 PM
  #265
1lowtc's Avatar
[quote="Squishface"]Lookin good man. That manifold is gorgeous.
quote]
18G
1lowtc is offline
Old 06-05-2006, 03:16 PM
  #266
Scion Dynasty
Squishface's Avatar
Hey Dezod, I know you guys know a **** load about turbos or anyone else,
How does the 18G turbo stack up with the evo 16G GT, and the turbonetics t3/t4?
I see that this turbo has an internal wastegate? sry i dont know much about turbos, but i know that there is something different with the wastegate, what are the pros and cons of this? I know my GST, had a T25 and it had a simliar setup.
Thanks
Old 06-06-2006, 01:11 AM
  #267
Revilo's Avatar
Yes, I know that you make the harness for the Ultimate... but what are we missing for making the ultimate PnP for the GReddy Turbo kit? jumpers settings? what are those? can you supply them? can you get them?
Revilo is offline
Old 06-06-2006, 02:39 AM
  #268
1lowtc's Avatar
http://www.greddy.com/tech/EMAN-ULT_Installation.pdf
Read this to learn about the ultimate. Page 7 explains jumper settings.
Jon
1lowtc is offline
Old 06-06-2006, 03:56 AM
  #269
Scion Dynasty
Squishface's Avatar
anybody on the 18G?
Old 06-06-2006, 04:26 AM
  #270
cdp1279's Avatar
Ok as for the 18G turbo being comparable to a big 16G the awnser to my knoledge is yes they are very close the 16G should be rated for about 380HP and i belive the 18G is 380-400 if im not mistaken they are both TD-05 wheels on the turbos.
I would also like to thank 1lowtc for his advice i was having the exact same cold start problem with the PnP Dezod harness and i switch jp2 over to the 2-3 setting today and it works flawless i am so glad you shared that info all this time i though i might have been the dezod harness and that is something i would have never figured on my own
On a side note i will hopefully have my injectors in about 10 days and it is the only thing left that i need so i can install my Greddy kit. I have a question or a favor to ask to anyone that actually has the kit installed anyone have a pic or can take a picture of the oil return flange mounted on the oil pan the picture in the instructions is very unclear i belive the flange should be at a 45 degree angle but just want to be sure i place it right.
cdp1279 is offline
Old 06-06-2006, 05:14 AM
  #271
Joe_Dezod's Avatar
Thanks
I can say that paul and I spend at least a half hour a day talking about some new turbo designs, brands, specs, whatever haha...
SO...
16G Evo and 18G are VERY simililar so I'd just stick with the 16G Evo, aka big 16G.
We use turbonetics turbos because of flexibility and quality. We can get a turbo that maxes at only 230whp or so, and then go as extreme as over 600whp on a t3/t4. With differenf exhaust housing options, wheel options, compressor options, the possibilities are almost endless. We are very happy with the S1 and it drives like a car that has larger displacement with a rinky-dink turbo. It makes 5psi at 2000rpms, and holds 12+psi past redline if need be. The S2 debuts this week and will really impress those looking for some higher numbers.
The turbo you choose will instantly make ur options slimmer for your manifold. The both uses different flanges (T25 flange vs T3 flange).
I'll get more into wastegate's soon... Gotta jet for a lil bit right now...
Thanks to the last two who helped us answer* these questions.
Joe_Dezod is offline
Old 06-06-2006, 08:46 PM
  #272
Prototype_xB's Avatar
the 18G and Big 16 both use a t25 flange? I had a t25 on my 1.7L civic and it was too small for my liking
Prototype_xB is offline
Old 06-06-2006, 08:51 PM
  #273
Scionetics
KAD
paul_dezod's Avatar
Yes they do.
Insn't it?!?!?!
Imagine on a 2.4L.
Old 06-09-2006, 06:21 AM
  #274
Revilo's Avatar
so if we buy the GReddy Turbo kit with the Ultimate option and the Dezod PnP harness for the Ultimate using this info (http://www.greddy.com/tech/EMAN-ULT_Installation.pdf)
we should not have any problems, right?
Revilo is offline
Old 06-09-2006, 12:56 PM
  #275
Scionetics
KAD
paul_dezod's Avatar
Pretty much.
Old 06-09-2006, 03:41 PM
  #276
legionscion's Avatar
Do you have any vids of the Greddy turbo ?
legionscion is offline
Old 06-10-2006, 12:35 AM
  #277
1lowtc's Avatar
I'll have one soon,
Jon
1lowtc is offline
Old 06-10-2006, 12:48 AM
  #278
Scion Dynasty
Squishface's Avatar
sweeet cant wait. Hows it running now? Got any numbers yet?
Old 06-10-2006, 02:12 AM
  #279
1lowtc's Avatar
I haven't got any dyno time yet,... I still have some rough spots around 4500rpms, but other than that its running great. I am going to up the injectors to 550's before I get dyno time.
1lowtc is offline
Old 06-10-2006, 02:21 AM
  #280
zer0's Avatar
Nice, going big!
zer0 is offline
Quick Reply: Well guys, I ordered a Greddy Kit
