Well, SEMA may have made a decision for me.
Old 11-09-2008, 10:03 PM
kiss_kiss_kill's Avatar
Default Well, SEMA may have made a decision for me.
On my way out of the convention center I heard KHUUUUUUUKHKHKHKHHHHHHHCRASHBANGBOOMGRINDGRINDGRIND. At first I thought my front bumper came loose and was dragging but I pulled over & it was still in tact so I but I popped my hood & my bearing blew AGAIN & shot the shaft out of the housing.
Luckily, I have a friend at Vortech & he was driving in my xB about 3 minutes behind me after it happened & he said he'll see what he can do. But dammit, the supercharger barely has 4k miles on it & its already gone through 2 bearings (first time it was Toyotas fault & it was replaced literally 2 weeks after the install).
Now I don't know wtf to do, say bye bye to boost all together, get the supercharger fixed (hopefully my friend can get it fixed for cheap), or just go turbo which I'm sure most of you will say. I swear something has to go wrong at EVERY show, dammit!
kiss_kiss_kill is offline
Old 11-09-2008, 10:16 PM
davedavetC's Avatar
awww tina, im sorry to hear that
time to turbo that beast (that... cute beast )
davedavetC is offline
Old 11-09-2008, 10:20 PM
jetlounge's Avatar
you have a lot of custom work done. it's hard to say... but basically you play...you pay. nothing is bulletproof. its the risk we take. no guarantee with turbo either. turbo guys/gals have bad luck too.
pics of the blown shaft?
jetlounge is offline
Old 11-09-2008, 11:11 PM
Custom work done yes, but not much under the hood, the supercharger which was dealer installed, headers which were installed before the supercharger was even installed, killerglass radiator hose that has nothing to do with with the supercharger & CAI. The supercharger was hand polished by me & was never taken off the car. No reason for the bearing to blow.
Old 11-09-2008, 11:26 PM
silverstreaktc's Avatar
they may foolishly argue that the heat from the header may have heated it up causing the shaft to get hard.....hot......i mean hot....and blow....out......blow out......yeah.....wow....awkward....
silverstreaktc is offline
Old 11-09-2008, 11:29 PM
Funny thing is, it's heat wrapped.
They tried to pull that excuse with me the first time. I'm like, uh, yeah, the cars been driven like 300 miles, highly doubt it'd kill it that quick.
Old 11-09-2008, 11:34 PM
java09's Avatar
sorry to hear! im selling my turbtoyotas stage 1 kit!! go turbo!
java09 is offline
Old 11-10-2008, 12:12 AM
gompka's Avatar
Yo do pay and you shouldn't get a POS supercharger from Scion for the amount of money that you do pay. That is a ridiculous thing to say.
Tina I have had the same problem, i'm waiting on a new supercharger from toyota, i will be replacing the stock crappy rubber sealed bearings with teflon sealed bearings. They will be open on the insides and the whole pulley side will be filled with grease, hopefully this is a fix that will make my supercharger last, mine made it 10k before it blew up.
PS when your bearings go there is a very good chance that your shaft is damaged, if it gets scraped up too bad it will spin inside the new bearings and the same thing will happen all over again.
gompka is offline
Old 11-10-2008, 12:27 AM
06SCtC's Avatar
Just because it's heat wrapped doesn't mean that it still doesn't get hot. You can heat wrap it, jet-hot it, and do anything else, but it's still gonna get hot. And you never know, the heat may from the header may have affected it.
06SCtC is offline
Old 11-10-2008, 12:30 AM
1_kLEan_tC's Avatar
Are you tuned or untuned?
1_kLEan_tC is offline
Old 11-10-2008, 12:31 AM
davedavetC's Avatar
lol yea but im sure the stock header with the "heat shield" gets just as hot if not hotter then an aftermarket header with heat wrap.... have you ever touched the heat shield after a long drive?
yea its hot
Old 11-10-2008, 12:33 AM
gompka's Avatar
Heat from headers breaking the s/c is a bunch of bull. In her case her header is ceramic coated, it probably runs cooler than a stock header with a heat shield. The stock headers get much hotter because the cat heats up, aftermarket headers don't have heat shields.
The reason the s/c bearings blow is because they are a crappy design, the rubber seal heats up too much and the small amount of lubrication leaks out of the bearings. No lubrication=blow up very soon. There are plenty of other superchargers that are similarly designed that last. No reason why ours shouldn't also. I have taken the whole s/c apart and from what I can tell, its just the bearings that are a problem. I will be modifying the new s/c when i get it and posting results, like I said hopefully it will be a fix everyone can benefit from.
gompka is offline
06SCtC's Avatar
^ trust me i know... i have the S/C. But I was just saying that she shouldn't think that just cause it has the heat wrap, doesn't automatically protect it.
06SCtC is offline
Old 11-10-2008, 12:36 AM
SoFloTC's Avatar
wow i thought ur car was turbod.... what the heck do u have a supercharger for ewww lol
SoFloTC is offline
SoFloTC's Avatar
dp ftl
SoFloTC is offline
Old 11-10-2008, 12:40 AM
gompka's Avatar
Its just that many people do not understand why the s/c bearings blow out. Its a bad design and crappy bearings. Doesn't matter if you run stock pulley and heatshield and drive like a grandma. They WILL blow sooner or later, and later is not too far off lol.
gompka is offline
Old 11-10-2008, 12:42 AM
06SCtC's Avatar
oh i know... TRD made the worst design with the S/C. But sometimes it will be warrantied, and sometimes it wont. You just hope it does...
06SCtC is offline
Old 11-10-2008, 01:17 AM
Music City Scions
rhythmnsmoke's Avatar
One word...."Turbo"...EOS
rhythmnsmoke is offline
Old 11-10-2008, 01:57 AM
Tuned with the module it came with.
Old 11-10-2008, 01:58 AM
I'm fully aware that it gets hot, That's obvious.
Quick Reply: Well, SEMA may have made a decision for me.
