View Poll Results: what grade of oil for boost
Voters: 11. You may not vote on this poll
what grade of oil for boost.
i've asked my dealership if i should switch to a heavier oil since i had the supercharger put on, and the tech said absolutely not.
so whatever you were using before, either the 5w30 or 5w20 depending on what year you are, stick with that, but i reccommend synthetic oil.
use whatever the factory recommends. usually, if its rated 5w-20, u can use 5w-30 in the hotter months.
u do not go any higher just b/c u boost. the bearing clearances in your stock motor havent changed b/c u boost. boost does not heat up your oil or engine anymore than it does stock if ur cooling system is still functional. Yes, combustion temps may rise, but oil and coolant remain constant.
Originally Posted by java09
but the 08 tC actually uses 5w 20.... wtf right... am i an idiot for using 5w 30 then? paul, chime in! what oil shoudl i be using?
steeze69
05-24-2021 02:57 AM
BlingSlade
09-05-2015 08:52 AM
