What size exhaust piping are you running?
In a stock Turbo car the compression ratio is very low (which is usually a mistake by car manufactures). Anyways The reason those cars want a big 3" exhaust is because they want a bigger pressure difference between each side of the turbo at any given RPM, therefore making it easier for the turbo to spool up (making more power) and making the turbo spool at lower RPM (reduces Lag). In a stock NA car the compression ratio is higher and the car can make the pressure build up on the hotter side of the turbo faster which makes a 3" exhaust less of an improvement over a 2.5" exhaust. So much so that other factors like exhaust velocity can start to become more of an effect on power then the bigger size piping but I still believe that 3” piping would be better but it might be possible there would be a power loss in the mid-range RPM due to the lower volume of exhaust gases but I bet the peak HP would increase at least a little with a 3” exhaust on our cars.
Originally Posted by RacingSolution
Going with a 1/4 " larger piping makes sense when you are adding bolt-ons.. but when you are doubling the horsepower/torque with a turbo setup, that 1/4" larger piping doesn't seem efficient enough.. You're dumping in a lot more air into the motor and need to get it out as efficient as possible with as little restriction as possible.
N/A cars want backpressure.. but on turbo's... backpressure in the exhaust will bog the turbo down ... the turbo itself will provide the backpressure..
keep an eye out for a 3" downpipe back coming from G Spec and Strommung Exhaust. Strommung is a HUGE manufactorer of Subie 3" and larger exhaust and he will be making a 3" for the tC and sold through GSpec.com. Still waiting for final production and numbers. But there will be one available for all of you who need or want higher HP
Originally Posted by tCUZZ
Hmm if I own a company that produce and sell 2.5" exhuast kit, I would favor the 2.5" over the 3". Make sense to me. .
Originally Posted by Souljah347
because with bigger piping the exhaust gases cool faster and take longer to push out. people think that some backpressure is needed which isn't the case. you use 2.5 because the gases stay hotter and travel faster (i'm not entirely sure the reason but i'v read a article by magnaflow on it). it's all about volicity, so yeah, running an open downpipe the exhaust gases escape faster, but it you have 3 pipe the gases expand and cool making it harder to be pushed out.
i know i could have worded that alot better but i hope you get the general idea
Open dumps perform best because you have no pipe there to actually limit flow. A good exhaust design will actually "scavenge" the exhaust, basically pulling air out of the motor. This is where efficiency comes in to play.
A WELL designed 2.5" exhaust will out perform a regular 3" any day of the week. If you're running 14psi or higher, then a larger exhaust may be necessary. We'll be proving that our little 2.5" packs a punch though when we release our race motors.
rcflyer15
12-05-2014 05:15 PM
Genesis
64
01-22-2005 01:02 PM
