what spring to get in BOV?
Ima be getting a Tial Q BOV. I dont know how to determine what spring to get in the BOV. I can go as low as 6psi spring. I was told to get a 10psi spring but I plan on running max 10-12psi of boost but will initially be running around 8 psi. Not sure if that is what is used to determine spring usage. Remember I am talking about BOV not wastegate! I know how to determine wastegate spring.
Thanks.
Thanks.
Oh ok. Well i know your running alot more psi than me. So i just wanna get a few more opinions. Thats all bro. I mean does boost psi not matter for the BOV? what does the spring psi mean on the BOV?
If you really want to make sure - use a smaller spring and find out if it holds the boost and doesnt leak, the move to the stiffer spring. I would say that a 12lb spring is prob what you need though. You just dont want it leaking - do you have a boost gauge you can test w/?
Naughtygoose
07-06-2015 09:59 PM
