What stuff to get to be 300+WHP?
#63
Innovative T3/T04E .63 A/R - 54 Trim Turbo
Stainless Steel TIG Welded Turbo Manifold
TiAL 38mm Wastegate w/ a .6 BAR Spring (8.7 PSI)
Mandrel Bent Charge Piping w/ Intake
2.5" Stainless Steel downpipe w/ 2.5" S-Pipe (extra value)
2.5" Dezod Turbo Back Exhaust
HKS SSQV Blow Off Valve
RC 550cc injectors w/ clips
Stainless Steel Braided Oil Lines & Oil Pan Fittings
FFC Large Bar & Plate Front Mount Intercooler
Emanage Blue, Tuned from Church's
This was also on a dynapack @ Church's ... But im only running 8.9lbs of boost!
Thanks Paul!
Thanks Paul!
#64
Originally Posted by Mightygnu
Innovative T3/T04B .63 A/R - 54 Trim Turbo
Thanks Paul!
Thanks Paul!
#65
Also, I plan going on with a 3" ZPI Full Turbo Exhaust in about 5 months when the price drops. I have a Magnaflow Catback right now, so that will help some than the stock one would.
#66
That just means you will lag a little bit more, but once your in full boost which till take a tad longer to reach, it will throw you in the back seat like me...
yea, I was going to get a custom 3" exhaust, but I'm not pushing enough power...
Once I build the bottom end/head, I'll be up there with Jeff!
you have quite a list of what you want to do... $$$
#67
Yea, that list is a 3 or 4 year span. I plan on getting 350WHP by next summer.
#68
all depends on how much money you want to spend.
Paul will be able to help you in every need possible. Probably beginning of next year, I will be building the block, but not quite sure yet exactly what I want to do with my car..
Keep in mind my car is an 2007...
#69
#70
no, 54 trim isn't the lowest, and lower is not better...
With a 54 it will spool faster then a 60 trim... but the 60 trim will spool later, but will provide a slightly better top end.
I did not go with a ball bearing either.
BlingSlade
09-05-2015 08:52 AM
