What is your Long Term fuel trim?
Old 10-16-2008 | 03:41 PM
enjoithis's Avatar
Default What is your Long Term fuel trim?
The reason i ask is because my car is suddenly running leaner and leaner after having nearly a perfect tune a few months ago. My fuel map is reaching 99's under boost and still not making enough fuel! Yes, the air got cooler but not that much cooler!
My best idea to why this is happening is because of rich spots on my map, which is causing my "long term" fuel trims in the ECU to slowly drop. With a snap on scanner i found that my long term trims are -36, and short term varies +/-5 at idle (of course after adjusting the map +20 duty cycles due to it being 16 afr's at idle...)
Does anyone else know what their long term trims are? Im running 550cc injectors, Dezod S1 kit. Should I reset the ECU and try tuning again?
Old 10-16-2008 | 08:26 PM
svencarlson07's Avatar
we shud just f the aem fic and get standalone lol
Old 10-16-2008 | 08:32 PM
paul_dezod's Avatar
Scionetics
KAD
-36 is a HUGE trim. You should be closer to like -7 or less. I have a local fella that has our kit that is gonna stop by today or tomorrow and I will check his e-mangle with fuel trims and report back.
Old 10-16-2008 | 10:09 PM
jjos1's Avatar
^ What is your injector pulse set at ? it should be around 486ms I had problems with that map you had started with because of the injector pulse being set to high. You should be adding around around 25% fuel up top at 8psi.
Old 10-16-2008 | 10:49 PM
purplenitroustc's Avatar
emanage FTL
Old 10-16-2008 | 10:52 PM
We don't have the emange we have the aem fic
Old 10-17-2008 | 01:22 PM
Guru's Avatar
sounds like something has changed, possibly a leak somewhere?
Old 10-17-2008 | 01:46 PM
enjoithis's Avatar
F/ic is correct... Pulse is around 486,s
adding 99% fuel @ 8spi!! how can i relearn fuel trims... can i just pull massive fule @ idle and let it re learn?
Old 10-17-2008 | 02:06 PM
CarbonXe's Avatar
Daaamn, you're almost at the max LTFT (I believe it's +/-50).
Are you sure your MAF and 02 maps are correct?
Old 10-17-2008 | 04:54 PM
enjoithis's Avatar
02 maps look just like Base maps from dezod, MAF is just about there too...
Paul, do you have any updated "Base maps" or any other maps for similar cars I can work off of?
Old 10-17-2008 | 04:57 PM
CarbonXe's Avatar
I remember someone had a problem like this, don't remember who...but it turned out that their MAF map was wrong...
Old 10-17-2008 | 05:19 PM
enjoithis's Avatar
What MAF Map are you using? Mine is based off the *C* map... which was made for 650cc and im running 550.. i bumped up the MAF map accordingly though..
Old 10-17-2008 | 05:21 PM
CarbonXe's Avatar
I'm still not boosted, so I'm not using any MAF map yet lol.
Old 10-17-2008 | 05:24 PM
enjoithis's Avatar
lol anyone else have a MAF/02 map thats working 100% on AEM F/IC?
Old 10-17-2008 | 08:42 PM
08superwhite's Avatar
i don't even use the maf map. i have it set in percentage at 0% and just set the maf clamp at 5.05. I have had 0 problems running it this way. it seems like i have more control over the tune by not using the maf map
Old 10-18-2008 | 12:38 AM
jjos1's Avatar
I worked from the maf map on aems site and set the o2 values based on MAP Load which is working pretty good for me. I can email what I have over to you to try if you want.
Old 10-18-2008 | 05:40 AM
enjoithis's Avatar
i have about 10 maps from various tuners / setups... they all look about the same, not sure what to do
Today i tried running differnt maps, alllll of them run lean.
seems like no matter what i do the car wants to idle @ 16AFR... unless i change my 02 map to 2.8 for idle
do 02 sensors go bad from not having cats?
Old 10-18-2008 | 09:29 PM
jjos1's Avatar
How much fuel are you pulling at idle ?
Old 10-20-2008 | 09:27 PM
enjoithis's Avatar
at idle fuel trims ~ -10, still idles at 15ish afr
Old 10-20-2008 | 09:30 PM
paul_dezod's Avatar
Scionetics
KAD
Hmmm. Maybe trying clamping the MAF a tad sooner, but this will overall lean out your tune. BE CAREFUL doing so! You may want to work more on your O2 skewing map as that can also alter trims drastically as well.
Quick Reply: What is your Long Term fuel trim?
