What are your LTFT/STFT????
Old 05-22-2010 | 12:46 PM
aparreira9586's Avatar
Default What are your LTFT/STFT????
i had my car tuned at dyno for WOT but now im doing my own street tuning in vac cuz im pulling -20/-30 fuel trims LOL i have 550cc and my tuner didnt tune ANYthing, so i was wondering for all of you that have been turboed for a while what are your trims?
I KNOW HOW TRIMs WORK and that u want them as close to 0 as possible and ive read the threads dealing with this... ive done mine a few times pulled the ecu fuse and trims are out of wack so im doing themm again, untill i get it right
and to you DIY'ers if you guys can post or email me ur injector maps from ultimate id like to compare (if your running 550cc)
aparreira86@yahoo.com
Old 05-22-2010 | 12:50 PM
also how is ur transition into boost with the ultimate, is there hesitation from the AFR from not going into open loop?
Old 05-22-2010 | 02:36 PM
Slow_2az's Avatar
i had thew FIC my ltft were 0 and occasionally +1 ....stft were around +/- 3 tops
Old 05-23-2010 | 04:32 PM
noone huh?
Old 05-23-2010 | 05:56 PM
Carlanga's Avatar
first thing I did was to make sure my O2 map was spotless in the vacuum area (FIC) per afr gauge, then I went into the fuel map and added fuel to lower the +fuel trims and subtracted to up the -fuel trims. The Long terms might take a couple of minutes to follow the short terms. It seems like you should take about 20-30% off of fuel to kick the fuel trims down in vacuum.
What I like to do is to use the injector size change option.
Ex. If I wanted to add 5% of fuel I would do the following:
700cc x .05 = 35
700 - 35 = 665
Then right click the table and under new injector input 665 and under old 700.
If subtracting fuel just flip the numbers. That will give you a good and safe idea to start. I found this myself when I started tuning for e85. I started by blending and eventually added the full 30% needed for e85 over 93 pump gas.
Hope that helps.
If you could, send me ur map with a good description of ur setup.
carlangaok@hotmail.com
Old 07-14-2010 | 12:03 AM
SoFloTC's Avatar
dude my fuel trims while cruising are like -30 lol wtf? and when cruising i hit a 10.00 wall studder at like 3k but if i start spooling at that area its ok just cant like cruise in it.. so weird.
Old 07-14-2010 | 01:13 AM
m6ar2cel6oTC's Avatar
Why don't you just contact mike instead of posting your issue. I'm sure mike will help.
Old 07-14-2010 | 02:40 AM
SoFloTC's Avatar
cuz i need to go actually get a tune from him 3 hours away not waste his time playing with a basemap... and hes busy lately anyway so im trying to do it myself until i go up there.
Old 07-14-2010 | 04:05 AM
ElevationTC's Avatar
Chad, this is how you make people look bad..
First.. Your on a basemap. That YOU tuned................................
Secondly. the fuel trim that your speaking of on the fic software is not your fuel trims from ecu. You need a scan gauge to see those.
SOooooooooo...
Thanks for the help marcello! Any updates bud?
Old 07-14-2010 | 04:25 AM
SoFloTC's Avatar
dude i never said anything about what im running having anything to do with you mike... i said i need to go get tuned by u and right now im ____in around with a basemap myself? whats the harm in that? nothing in my post was directed at you besides saying i dont wanna waste your time so how are u taking that post the wrong way. calm down ging.
Old 07-14-2010 | 06:02 AM
SOooooooooo...
Naw I ordered the street pressure plate which it will be rated to 595 and it's half the pressure then the extreme one I had I already got all the bearings and should start working on it by next week. I'm going to orlando this weekend I wish I had my car I would have driven to get my generous tune from you but sucks I don't have my car ready. Hey did you ever take the pan out and checked what we talked about?
Old 07-14-2010 | 02:53 PM
paul_dezod's Avatar
Scionetics
KAD
My trims on the xB2 are max at -5 and most at +2-3
Old 07-14-2010 | 03:39 PM
Yup, It worked =D It ended up being the timing plate was damaged due to a cheap agency power pulley being damaged and it cracked the key and damaged the plate!
Old 07-14-2010 | 05:16 PM
Wow who would have known. So you took out the timing cover then?
Old 07-15-2010 | 01:30 AM
skinnayyy's Avatar
Team Scionara
my fuel trims are always at 0 +- 3 sometimes in everything but idle. idle.. well that's a whole 'nother story ><
