What's a good intercooler for the TRD S/C ?
you don't need any kind of intercooling unless you plan to run something like 12 psi of boost.
and using an intercooler on the trd supercharger costs you 2 psi, so lose power anyway.
if you want to cool the intake charge, you have to use water/meth injection, but if your stock, don't waste your time and money with intercoolers.
yeah, when your pushing those boost levels you need to start cooling the intake.
the most powerful supercharged tc that we know of was icenine's tc. his name is karl werbeck. he dyno'ed 311 whp with a 12 psi pulley, custom supercharger cams from rippmods, and ofcourse supporting mods like tune, injectors, water/meth injection etc. but he doesn't seem to post on here anymore.
but that is alot of expense to go into for the supercharger.
Scion Tuners
Originally Posted by Gerard_gmaiz
I will install the 12.5 psi pulley do you recomend any intercooler or you suggest to leave it with out?
and meth injection is far too costly
go 12.5 IC (and the rest of the necessities ) and im sure youll be well into the 300's
You loose boost with an intercooler, so you have to make up for it.
Somone on here is selling an intercooler for like $900
Water/meth is around $350.
Scion Tuners
i got one off of my friends markIII supra... cleaned it up a bit and is ready to go... the problem with meth is it is coslty to keep up, not as a base price. and dont you need to tune to the meth?
methenal is cheap. You buy it and mix it with water, and it does not run all the time. You can tune it yourself easily. You set it to come on at eithet WOT or at a given boost level. That way, it will only spray when you are accelerating very hard, when you need it.
with an intercooler, you will need a piggy back tunning system at around $400-$600 with harness. Add in a dyno tune at around $300. And with the price of the intercooler and you are talking $1800-$2000. Oh and a wideband 02 sensor, $300.
TheTripleC
01-04-2015 06:46 PM
125, 2013, buy, diy, dyno, intercooler, intercoolers, psi, pulley, scion, size, supercharger, tc, trd
