Whats required for 11.5psi on the s/c
Originally Posted by kikcaffine
Hey princess.
You have the double walled seal, 2 steps colder will work, you dont really need bigger injectors. Your car will run and idle really ____ty with 550's. Keep the stock 410's in it. You will be a-ok with that set up.
Wuv you.
*kisses*
Wuv you.
*kisses*
Hey princess.
Wuv you.
*kisses*
Wuv you.
*kisses*
I would not run those... Speaking from experience. Ask paul from dezod what happened to 550's at 10.5 pounds.. Max duty cycle. 550's on a fic will do you good with a good idle. If you run 410's at 11.5 pounds you will need kikcaffine to rebuild alot more then ur s/c.
i'm running 700cc's @13.5 psi. idle is pretty normal. injector size has been debated like elevation said.
i thought your s/c crapped out on you? did you get it taken care of through warranty?
Subaru86
Scion FR-S ICE & Interior
09-10-2015 08:11 AM
umnitza
09-01-2015 08:06 PM
umnitza
08-21-2015 12:35 AM
