when is it too late to turbo?
I think what he is worried about is if there is a point where it would be inadvisable to put a turbo setup on because the engine is "worn" and/or unreliable.
It can *definitely* be too late to add a turbo. If the engine is failing a compression test (or the compression is not well within specs) I most definitely would not implement F/I.
A compression check can be done at any dealer, will probabyl cost you $100 or so. But at 18K miles, I don't think it's likely that you have a compression issue, unless you are having engine troubles.
I did one on my car in lab before my tear down and I passed the CLT and Cylinder Pressure test.
I dont trust autozone to sell me grease rags.. much less touch my car
But aside from that, you can purchase the gauge and do a pretty good compression and leakdown test on your own. The specs should not be hard to find. But at 20k you should be fine.
^^ exactly. Lets think abotu this for a second: certitied/trained mechanics who can be held responsible for any damages (dealer) or part time guys who work at a nat'l chain with *no* training/certs.....I'm gonna go with the dealer on this one.
Scionxa180
09-24-2015 04:51 AM
