This is when you know ur transmission
is done, when you are driving and you start throwing CEL lights for "Torque Converter Stuck Off". Yeah, my tranny is done. Daily cruising in it is like whiplash when it shifts!!
-transmission mount
-shifter assembly and linkages
-clutch slave cylinder and reservior
-clutch lines
-manual ecu
-clutch pedal -brake pedal
-manual starter motor
-manual half-shafts/axles
-clutch
-flywheel
To do the swap what else will I need besides whats listed above.
-clutch lines
-manual ecu
-clutch
-flywheel
Wow, someone is finally going to do an auto to manual swap. A lot of people talk about doing it but I don't think anyone's actually gone through with it. You'll be a first!
On the other hand, I won't hold my breath. I'll believe it when I see it.
Document the process! I'm sure there will be lots of interest on how this works out for you.
Originally Posted by 318_tC
I got the gauge cluster anyway I found a wrecked tC and got everything out of it for the swap.
You can use an mt ecm. Codes are not stored in the ecm but in the transponder brain. But you do have to know a special trick to get the new ecm and the transponder brain to talk. Also like Munch said. The cluster will work no prob. The auto section will just be backlit but nothing working. You can desolder the leds to get rid of the backlight issue.
BlingSlade
10-19-2016 12:39 AM
