white smoke coming out!!!
#41
No there isnt any oil pressure going back to the oil pan to my knowledge, so and dip, or kink, will cause the oil to puddle up and restrict the flow. I believe this happened to my buddies turbo as well.
Ace: I have a tendency to see very small details. Maybe it was the camera angle or the flash, but I clearly see it either flatten out near the fittings, or actually dip right before going into the pan.
#45
yeah i'll just get some thermal exhaust wrap.... what are the chances its my piston rings being blown up? and my idle is really rough too... it bounces between 300-1000 rpm.... would that be the tune?
#46
turn car on pull dipstick out...if u see smoke outta that or outta the cranks crase breather during idle then u have a bad ring
#47
hmm... a bunch of smoke was coming out of the turbo last time... but we kinda knew it was blown... we got a rebuilt turbo that we just put in. as of now, the condition of my car is... the check engine light is on, sometimes it tells me theres a misfire in cylinder 1, and most of the time im getting the crankshaft sensor error... but my main concern is the smoking problem...
#48
so the new one is smoking too? hmm idk could be oil burning off the exhaust and head that was trapped in it......but the cylinder 1 and crankshaft codes seem like tuning/aem resistor codes to me
#49
oh no new one isnt smoking.. well at least i hope not.. but i kinda want to solve the codes first and make sure all the wiring is correct before i start up the car with the new turbo in... man i really hope this new turbo isnt going to smoke... i invested more than what i expected to already
#51
Use a -10an line.
Labyrinth seals can handle a max of 100psi. You should not be seeing that much pressure by the time your oil feed takes oil from the head.
If you had a turbo fail and spew oil odds are there is residual oil in your intercooler and you should remove it and flush it out. Let it dry then reinstall.
#55
oh my goodness you sure are lucky that you didnt drive for long...that was letting boost into your crankcase and putting stress on all the seals on your motor and piston rings......did u get tuned like this?
and how did u realise u messed up so badly
#56
also we fixed the crankshaft sensor problem... it turned out that we threw a resistor onto
cam1 magi+ to crank1 magi-
instead of
cam1 magi+ to cam1 magi-
crank magi+ to crank magi-
theres another CEL but i think its telling me im running rich... really rich... lol i was smelling gas at idle and it was bogging
but we'll see after tuning!
