Why i wont be using je pistons ever again!
#41
ummmm...piston slap is no good no matter if its the first five minutes or the whole time that ruins the cylinder walls...usually piston slap happens when the skirt on the piston is broken or cracked. it sounds like your piston isnt seating right to me. thats just my input. also what did you bore it out to?
dam i guess my plastic gauge must of been off... i used a drill and a honer..
i had to bore it to 89mm but the pistons are 88.5
#43
#46
#47
#48
#49
Noise from skirt slap is normal with almost all forged pistons in almost any motor, until the engine warms up. Je's are good pistons and handle some serious abuse before failure. Never noticed if they were any more or less noisy than others in motors I have built ( mostly sbc)
#50
You also didn't notice that the last post in this thread was in 2009
#54
Since it was brought up, this is why you should have the pistons first before doing machining & also have a professional do the machine work. I am not too sure about using plasti gauge to check the puston to wall clearance either. I know they make special micrometer for this. Plasti gauge is perfect for bearing clearance.
Sent from my SGH-T999 using Tapatalk 2
#55
BlingSlade
10-19-2016 12:39 AM
