wideband install Q
wideband install Q
i was wondering where you guys/gals are tapping the O2 sensor for the wideband. i was told on the S pipe. If so is it before or after the OEM O2 sensor. can i tap it on header or is that a no no. i also need a DIY on gauges.( boost,volt and wideband) wiring up the gauges b/c i dont want to mess anything up and start blowing fuses or the gauge. thanks for the help.
For the gauges look in the tech section. I'm pretty sure there is a DIY in there for autometers.
I have my wideband sensor welded into the spipe. Anywhere in there should be just fine.
not the same application, but will help you out a bit.
http://www.dsmtuners.com/forums/arti...-wideband.html
Originally Posted by CarbonXe
My S-pipe has 2 bungs in it already, so I can't answer that question..
The gauges should have instructions for installation. What kind of gauges did you get?
spawnconnery
12-18-2014 08:38 PM
TheRedBox
31
12-02-2003 04:53 PM
