Your AFR Readings.....
Well i Put the AEM UEGO Wideband in today and tell me if this is normal....
1st-4th gear WOT is Constant 11.9-12.1 Full Boost 6.5psi Never Higher Never Lower
5th Gear WOT is 11.2-11.4 @ WOT Full Boost.
My partial Throttle driving normal reads 14.7-15.5 Constant.
Do these numbers sound right for a car with stock injectors and no engine management?
Isn't ideal 11.5-12.5 AFR good?
Why am I at that with no tuning lol?
^^^ What kind of wideband to you have? Most wont read below 10.0. WAY too rich.
Firestorm- I dont think your idle should be that off. Most factory tuned car idle right at 14.7. If you are still using the stock ecu tune then you'd think you would be right at 14.7 with or with out a turbo.
Yeah, your WOT is fine, and with tuneing, you could get your partial throttle down (i'd throw the black box back on) but your idle shoudl not be that lean. Where is it at when your cruizing around not in boost?
OH, and your running good because the ZPI kit was designed to run like that without tuning. As soon as you put an IC on or some injectors, you will need tuning.
Well, if your AFR sensor is in the S-pipe (like mine) and you have an exhaust leak between the S-pipe and Down pipe (like I did) then your readings arent' entirely accurate. It is reading leaner then it really is.
Depending on the severity of your exhaust leak, it may be that when your running it, there is not much of a leak cause it's pushing past, but when your ide, the exhast gases are moving slower so they are going out the leak, bypassing your AFR sensor so it reads lean. But your car will still run fine because the ECU reads the AFR from the 02 sensor in your downpipe, and there is no leak before that.
What code are you getting?
rancur3p1c
07-12-2015 07:59 PM
Prototype_xB
40
01-09-2007 02:01 AM
