Is your computer smarter than the WOT box?
Old 07-23-2010 | 06:51 AM
maherdan82's Avatar
Default Is your computer smarter than the WOT box?
Ok, so I have the N2MB wot box with two step installed on my turbo tc. My question is does anyone get a check engine light with this installed? I have everything installed right and the program is right, but when I use it I get a cel. My codes are a coil pack malfunction while two steppin and a miss fire flashing cel when wot shifting. Everything works as it should with the box, except for the cel. I spoke with N2MB and they told me I shouldn't be getting any cel. Sorry if I don't beleive them concidering they sent me the box programmed for the SRT-4. So only people with this box please chime in.
Old 07-23-2010 | 06:53 AM
NVMyTc's Avatar
As far as I know everyone gets a flashing CEL when 2-stepping
I know I did when I had my WOT Box
Old 07-23-2010 | 07:03 AM
maherdan82's Avatar
Ya, I figured as much. Considering how the unit operates I can't believe the manufacturer would tell me it wouldn't throw a cel. I think N2MB is full of sh*t. They kept on telling me I installed it wrong even thoe it works perfectly except for the cels.
Old 07-23-2010 | 02:55 PM
Carlanga's Avatar
I get misfire cels when no-lift shifting past 6000-6100 rpms. Anything under that and I generally don't see anything other than maybe cel light flashing and going away. I have not used the 2-step in a long time, but I can't recall seeing anything. In reallity ur car is actually misfiring to be able to do those things. That's why one of the connections is to the coil pack. If u get some free time, pull the spark plugs. I'll notice that cyl.4 is gonna have a leaner look than the rest. That's of coarse if u hooked up the wot to that coil pack.
Old 07-24-2010 | 01:45 PM
maherdan82's Avatar
Ya , I just don't see why N2MB just don't admit there product will throw a cel. Mine is hit or miss. If I don't 2-step for longer than a second I won't get a cel. Also the flashing cell while WOT shifting just started. Guess the comp. won't trip anything until it see's the problem a few times. Wonder if I shorten the WOT shift timing? Might cause the miss to be fast enough the cel won't flash.
Old 07-24-2010 | 04:38 PM
Tc4Eva's Avatar
Team ScionTific
When the CEL flashes its the ecu telling you that you have a misfire bad enough to seriously damage your Cat. A misfire is considered a Type A code, which means that as soon as it sees a problem the light will come on. There is a monitor that well monitors the cat that is run continuously and once it detects a problem that can damage the cat it will light up the CEL
Old 07-25-2010 | 12:23 AM
NVMyTc's Avatar
Hmm I didn't know that, cool stuff
Old 07-25-2010 | 02:08 PM
maherdan82's Avatar
Good to know considering I still have a secondary cat. For now that is....
Old 07-25-2010 | 07:08 PM
Tc4Eva's Avatar
Team ScionTific
Also as a side note, the CEL will only come on when it sees/thinks that the car will produce 1.5 times the federal emissions limit on that car.
Old 07-26-2010 | 04:46 AM
rhythmnsmoke's Avatar
Music City Scions
Every device be it the WOTbox, or an EMS with 2step, will throw a CEL when you engage the 2step.
N2MB probably don't know that about our cars.
yhwhdesign
06-11-2021 04:34 PM
DryToast
08-04-2015 03:59 PM
kanundrum
Regional - Mid South
08-04-2015 05:23 AM
herbn44
07-24-2015 03:26 PM
