zpi turbo kit owners please help
Old 06-23-2009, 01:49 AM
BOOSTit06's Avatar
Default zpi turbo kit owners please help
Ok so I have a zpi stage 1 kit with an upgraded 20g turbo, This is my 3rd turbo with this kit and the seals just started leaking on this turbo I always make sure the lines are clear when installing a new turbo pre-oil it, I have a turbo timer. I run 10-40w oil. Has anybody else ran into this much trouble using the mitsu turbos?
BOOSTit06 is offline
Old 06-23-2009, 03:32 AM
draxcaliber's Avatar
why are you using 10w30? i don't think it is necessary to go beyond 5w30. i think one of the problems people have with blowing turbo seals are having too much oil pressure.
draxcaliber is offline
Old 06-23-2009, 03:35 AM
equinox2355's Avatar
x2, running anything above 5w is asking for trouble. running 5w30 would be the best (5w20 if you dont mind thinner oil, but it may give you a better MPG lol)
equinox2355 is offline
Old 06-23-2009, 03:45 AM
thendawg's Avatar
Depends on oil temp 10w40 works very well in many boosted applications where oil temps get high - wouldnt recommend running it in the winter tho lol - i live in oklahoma and it regularly hits 100* in the summer I run 10w40 RP form about april-sept and RP 5w30 in oct-march. I usually change the oil twice in each period which avg's out to 3-4k per oil change
thendawg is offline
Old 06-23-2009, 05:45 AM
Mrsanchez925's Avatar
Same, I run 10w-40 during summer, but as soon as winter hits i will be using 5w-30 once again.
Mrsanchez925 is offline
Old 06-23-2009, 06:25 AM
Nightbeat's Avatar
ditto
Nightbeat is offline
Old 06-23-2009, 09:44 AM
BOOSTit06's Avatar
I run 10w-40 during the summer due to the heat, once fall rolls around i go back down to 5w30. I just cant figure it out though. :/
Old 06-23-2009, 01:41 PM
THansenite's Avatar
I run 10w-30 in my car and haven't had any problems.
THansenite is offline
Old 06-23-2009, 03:26 PM
thendawg's Avatar
You dont live where its 90* by 10amlol - and still 90* at 10-11pm
thendawg is offline
Old 06-23-2009, 03:55 PM
THansenite's Avatar
Haha, true, however, this week, it has been. lol
Old 06-23-2009, 06:34 PM
thendawg's Avatar
Haha yea heatwave i guess its 102 here right now
thendawg is offline
thendawg's Avatar
I went to lunch and dropped a piece of ice on the sidewalk - in 30 sec it completely melted AND evaporated lol
thendawg is offline
Old 06-24-2009, 03:27 PM
RichTc's Avatar
Default Re: zpi turbo kit owners please help
It sounds like it's something specific with your set-up as people on here do run 10W-40. A little more information might help.
What is your oil pressure?
When installing the new turbo, did you crank the engine (with the ECM fuse out) to build/circulate oil prior to start-up?
Is there a build up of oil on your oil feed or return line? How high up is your oil return line taped intot he oil pan?
This is probably the simplest, but do you have a turbo timer or wait after stopping before turning the engine off?
Take a look at those and let us know what you find.
RichTc is offline
Old 06-24-2009, 07:39 PM
OuterHeaven's Avatar
I have a ZPI kit. It came with a 4an oil feed line and I think that is too big. I went through 2 turbos before I added a restrictor to my oil feed line and the smoking actually went away. I did not need to rebuild my turbo at all. Now I think my original 16g is not damaged and you should defiantly look into getting an oil restrictor.
OuterHeaven is offline
Old 06-24-2009, 09:09 PM
Carlanga's Avatar
-3an oil feed line, problem solved.
P.S. take it easy the first 15min on cold start
Carlanga is offline
Old 06-25-2009, 02:54 PM
THansenite's Avatar
Where did you get your restrictor from? Size? I should probably get one for my setup.
Old 06-25-2009, 03:26 PM
CarbonXe's Avatar
x2.
CarbonXe is offline
Old 06-26-2009, 02:13 AM
BOOSTit06's Avatar
Yea curious to what size restrictor you used and where did you get it?
Old 06-26-2009, 02:21 AM
dave2610's Avatar
hmmm maybe i could use a restricter
dave2610 is offline
Old 06-26-2009, 05:50 AM
LOL actually I had a hard time finding a fitting that would work so I actually just used some 2 part epoxy and a 1/16th of an inch (.0625") drill bit and just made one using the adaptor that is on the turbo oil feed inlet. It was very simple but my car was not useable for over 24 hours. It may seem ghetto but it has worked for over 5k miles now.
Quick Reply: zpi turbo kit owners please help
