**tC** Help make Fog Lights stay on with High Beams
The factory fog light setup is wired to turn off when the high beams come on. My camaro was the same way. In the Camaro, I was able to ground one wire to the frame and the fog lights would stay on with the highs, but Im not sure which wire to ground and whether or not it would work the same way.
Unique Scionikz
i dont think it'l work the same way as yer camaro. it shouldn't be too hard to figure out tho if i took a look at it... it would seem like u would need to just re-wire the fogs so they only turned on with a switch... it wouldn't matter if yer headlights were off or on highbeam. i'm not sure if u did this already or not.... are they wired through a relay of somesort?
Yeah...theyre wired through the factory relay. Im pretty sure that when the High beams come on, the ground is removed from the relay and the fog lights turn off. Regardless, it seem that one wire should do the trick to make it do what I want.
Unique Scionikz
try it and lemme know.... i need to meet up with you soon. the drivers side view mirror signal is havin issues.... one of the led's is flickering... ohh and i wanna finish my cupholder project. :D
carid
01-08-2015 11:33 AM
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
TheTripleC
01-04-2015 06:46 PM
umnitza
12-01-2014 06:26 PM
