#74 LED Doesn't Fit in Holder ?!?
So I bought a #74 Mini Wedge Base Blue LED from superbrightleds.com, and the base of the bulb does not fit into the "bulb holder" in the Auto Shifter piece. I was able to get the same exact bulb into the cubby hole holder, but for whatever reason the holder on the Auto Shifter piece doesn't accept the LED. It kind of just rests there and makes contact but does not go all the way in and "click" it seems as if the base is a bit too big.... Should I shave a bit of the inside of the holder down or what?
no it was easy to install it..
wait.. u bought this one:
74-xHP Wedge Base LED Bulb
High power SMD LED with wide beam angle - 6 lumen
Small Wedge Base LED bulb (74 type) 3/16 inch wide base, 3/4 inch overall length
Select LED Color
$ 2.49
i think i bought this one:
74-x Wedge Base LED bulb
Small Wedge Base LED bulb (74 type)~ 2 lumen
3/16 inch wide base, 13/16 inch overall length
Flat tipped LED produces wide beam angle
Select LED Color
$ 1.19
so u might have to order the other one what i got...
oh one thing.. u could try this too
74-WHP3 Wedge Base LED bulb
3 High power White SMD LEDs with wide beam angle radially mounted - 15 lumen
$ 3.49
--- if u can pls get one of the 74-x Wedge Base LED bulb and of the 74-WHP3 Wedge Base LED bulb
and do a comparo/ write up.. THX!
Select LED Color
$ 2.49
Select LED Color
$ 1.19
$ 3.49
XB06
05-30-2015 03:42 AM
TheTripleC
01-04-2015 07:46 PM
