8" components in front doors of tC (Updated w/pics)
Has anybody installed 8" components in the front door of there tC? Mine will be in this Monday and I will post pics of the install. If you have done this or thought about it, let me know what ya'll think.
Here are some pics of the install
THESE SOUND ABSOLUTLY AMAZING, THE BEST PURCHASE YET
(These speakers are also Full Range Speaker)
This will be for strickly Mid-bass. Its the 15-msync8 components made by Memphis.
I work at a audio shop here in MS and the local memphis sells rep has them and they are the sh__! Definitly not over kill. I play drums and I want to fell every note. MEMPHIS CAR AUDIO RULES!!!!!
I actually have been considering this. I was going to use the ED mid bass. Try and fiberglass them in myself in a sealed enclosure.
Whats the mounting depth of the 8s you want to use? What airspace do they need?
They run about $250 on ebay, $400 retail. You shouldn't need to glass anything because it going to be behind the door cover. I'm cutting a 1" baffle and sealing it up around the baffle with silicon.
Re: 8" components in front doors of tC
I think it can be a good solution for midbass, but only when it's midbass frequencies only, such as a bandpass signal from 50Hz to 200Hz, with a sub handling the lower freq's and midranges-tweeters (located elsewhere, such as the kick-panels) covering everything above the MB's low-pass point. If you're not going to do a 4-way system (preferably at least tri-amped, if not quad) Then I wouldn't use 8" drivers in the doors, unless I was going to pair them with under-dash mounted HLCDs that produced full output down to 800HZ or lower, along with a sub. Using 8" drivers to cover frequency ranges larger than and/or outside of what I stated often results in less than acceptable sound quality, especially when they're located so far off-axis from the listener and the path legnths from each driver are so unequal, which is exactly what you have when placing them in the tC's doors.
That's deep, good information. I have only heard the final product with a slightly bigger amp and was throughly impressed. The components come with a option to mount the tweeter on the woofer. Go check it out at http://www.memphiscaraudio.com/. Thanks for the advise.
I will be doing this soon. I am going to try the 8" midbass in the door. I ordered some baffles that I hope will allow me to do this and I will post pics. My midbass are fairly shallow. I think like 2.75" with a small neo magnet. I forgot to mention, I had these 8s in the door of my civic, which was a lot of work to get them in. I am sure I will get them installed it is just a matter of how much work to do it. I will be pairing mine with a 4" mid and a 1" tweeter in kicks.
I have installed a test speaker of the same model and everything works great. The window is still fully functional. The only problem I had was the bottom of the door is alittle mis-shaped due to having to slightly force the door to snap back together. You don't notice any difference and the door is snapped all the way around. I have pic of the install and will have pics of the finished install tonight, but I need you guys to tell me the easiest way to do this. I tried last night and can't get any on the post. I have a 8.1 meg Sony camera if that helps. I also read the ? and still no luck.
It's only when people try to use an 8" midbass over too wide of a range when there's an issue, such as when it's required to produce midrange frequencies to match a small tweeter, such that the crossover point is fairly high. This is further compounded by the stock door hole location in the tC, relative to the listening positions.
If anyone really wants an 8" MB in the doors and only a 2-way system (no MR for the range from MB to tweeter), I suggest you look into this setup, or a similar component set from one of the few other companies that offer them.
example - your sub plays at 200 down tune the mids at 180 up this way you have no gaps in the frequency response. Using an rta will show the gaps in the freq that you need to fill and adjust accordingly via crossover gains. if passive crossovers are used, then use the closest setting to the frequency response of the given speaker.
