after 8 hours still no luck with my remote start PLEASE HELP
if i could get ahold of my installer i will ask him how he did mine. he did the clutch bypass with windows mods, tilt sensor and the works with no issues. you must be missing a wire or have a wire hooked up to the wrong car wire. reverify your wires.
Originally Posted by Harmonic_tC
Originally Posted by Rebeld321
Ask him to double check the wiring on the relay for the second starter. it's probably sending a negative pulse cuasing the fuse to blow.
It could also be the way he wired up the relay for the clutch bypass. instead of wiring a relay to it, just connect the two wires at the clutch switch. that way it will always be bypassed, you wont have to press your clutch to start your car manually. its quick and easy.
Just my 2 cents, if you just connect the 2 wires on the clutch together and leave it that way, you will not have cruise control any more. You need to wire up 2 relays and have one for the switch at rest at the top of the clutch pedal and one at the bottom of the clutch pedal. Its been awhile since ive done one otherwise id tell you exactly how to do it. Out of the close to one thousand (I keep a list just for fun) of remote starters i have done, the TC is one of the easier ones.
Good Luck
if you were closer id finish it for ya, sorry
Good Luck
Thanks for the insigt, i had no clue that the clutch disabled the cruise control, i need to go back and rewire mine.
i have been installng remote starts for alomst 5 years now.. the tc or and any toyota/scion/ lexus are actually farely easy... now on the tc... there are two switches on the clutch... did he bypass both... or just the bottom... if the relays in the remote start brain are clicking that means theres crank there... just the fact that the clutch is not pushed in will blow fuses eventually...now its either he didnt bypass the clutch properly or he wired the second starter incorrectly like previously stated....
thanks for all the help guys he finally got a chance to look at it again yesterday and when i told him about the two spots on the clutch that needed to by bypassed he fixeed it right away.
airmankevin1
02-14-2018 01:23 PM
mw1957
03-16-2015 06:00 PM
