AMP TO BATTERY.... WHERE DOES THE WIRE GO ON A TC???
I CANNOT find where the power wire for the amp goes through the firewall on the TC, i have looked.... i have tried the little cone thing behind the pedals, i have looked in other posts and found nothing. Does anyone have detailed advice or even possibly pictures?????? Thanks
for 4 ga. wire: get a 5/8" drill bit, go about a foot above the dead-pedal, there will be a piece of insulation already cut out....drill a hole here and put your grommet in.....it will come out on the upper right side of the engine bay (when looking at it from front)
edit:
If you're uncomfortable with drilling a new hole in your firewall, look at Mandos's pic for grommet probing....hehe i said probe....
edit:
Yeah I went behind the pedals below the factory harness. A word of note: dont be like me and feed the wire from the engine compartment to the back instead of into the engine compartment. It was a _____ to pull like 15ft through there when I could have only pulled like 4ft into the engine bay.
Now I just have to get my 1/0 run... damn ____ty weather!
Entering through fire wall
Through the Brake retainer metal thing(there's a nice big hole at the top)
Coming out of the break one and into the clutch metal:
After that, just run it down the corner of the car behind the wire bundle and under the carpet....YAY
Ok...I'll get these images fixed...sorry guys For now, just click on them to see what I'm talking about
Now I'm having trouble putting the wire through the firewall. I found the grommet that you speak of by the steering wheel by I can not for the life of me find where it comes out on the other side! There's so much ____ in the way! Did you have to jack the car up and take off a wheel to find where it came out??
Step 1: Gut car.
Step 2: Lay down in car, head under the steering wheel.
Step 3: Shove hands up in the dash
Step 4: Cut
Step 5: Jam wire through a good foot or so and you should see it pretty easily.
Step 4: Cut
Got it through, easier with two people instead of one.
I didn't need to gut the car. One of my biggest fears is creating rattles, my car is rattle free, *knock on wood* It was easier than I though. Mandos, you're the man, without those pics I would have never figured it out. Thank you!
Wrencher
07-29-2015 02:38 PM
