Amp and Sub Questions
OK, So I just ordered my new sub and amp and I was hoping some of you could help me out with a few questions. First, the new sub I'm getting is a Rockford Fosgate PL1-112 which handles 150 watts RMS at 4ohms. The amp I'm getting is a 600w PowerAcoustik that does 95 W RMS x 2 ch at 4 ohms, 120 watts x 2 channels at 2ohms, and 240 watts x 1 channel Bridged at 4ohms. So what would be the ideal setting for the best performance. Also, is it ok to mount the amp on the subbox. I've heard of a few people doing this so its easier to remove for space. I'm really just looking for a good place to mount it without drilling into the car really. Something easily movable would be ideal. Any thoughts anyone? Thanks in advance for the help.
Re: Amp and Sub Questions
If you have any more questions, I'd be happy to help
I see. What about the power settings. Would just powering it at the 95 W RMS be under-powering it too much. If I did it bridged is there any way to reduce the power down closer to 150 RMS? Is that adjustable at all?
You really don't have anything to worry about, bridge the amp to 240w x 1 and you'll be fine
EDIT: And yes, 95W is NOT enough. 95W means that at 100% volume, you'll get 95W to the sub, an believe me, it needs more than that. Your sub probably needs 95W at 50% volume to sound the way you want it to
i don't really agree about the not mounting amps on the box itself. i have done it numerous times and never had a problem. if my box was big enough to actually mount amps on then i would be doing it.
But I'd trust tcguy over myself, most of what I really know about car audio came from his help, and in fact several components of my own system are from his suggestions, so I'd say you're safe with his opinion.
Awesome, thanks for the help. Sound's like I'll just set the gain at around 3/5 the way up just to be safe. That should keep it from blowing it. I still don't know about the mounting on the subbox. But if its safe to use powered subwoofers with the amp built in then then you would think that mounting it on it would be just about the same effect. Plus, its not a super loud sub so I would bet that it would be ok. Its going to vibrate the whole area anyways. Guess I'll just have to see and use it as an experiment. Hmm...how about a poll.
Here's a good tutorial on gain setting: http://www.diymobileaudio.com/forum/...read.php?t=542
Try to use a dynamic track to adjust gains (one with a WIDE range of lows, mids, and highs so you can adjust for most any other song you'll listen to. Just turn your volume up until you hear distortion through your door speakers, then back it off until the distortion disappears for the most part, then just add gain until you hear your sub distort at that level of volume. Then back it off til the distortion is gone.
Good point. So really the best way to get the best sound is to just raise the gain slowly until it distorts then lower it little from that correct?That giving it the max amount of power the sub can handle. So too much power is what makes it distort then right?
Good point. So really the best way to get the best sound is to just raise the gain slowly until it distorts then lower it little from that correct? So too much power will make is what makes it distort then right.
But if you have any issues, just let us know, I'm on here every day pretty much, so I'll always be around to help
Ok cool. Good information to know.
i have a component speaker set that is rated at 60 watts rms per side. i have 205 on tap just for each mid. right now the tweeters are running off of the HU (so only about 22 watts per side) but i plan to put an amp that can do about 80 watts a side to them as well.
will they blow? if i can actually stand to listen to it loud enough to use all of that power for a long period of time, probably yes, but i won't be. it's a great thing called headroom.
