Avic D3 & Pac SWI-PS Problem!
Old 01-26-2010 | 11:14 PM
chowee21's Avatar
Default Avic D3 & Pac SWI-PS Problem!
I just installed the Pac SWI PS in my 07 Scion tC and programmed it.
The problem is the "mode" button on my steering wheel is not responding during programing. I have tried to just program the mode button alone and its like its not connected, but all the other buttons work fine.
Help!
Old 01-26-2010 | 11:58 PM
mattieg's Avatar
are you pressing and holding the button till the led on the swips turns off?
Old 01-27-2010 | 06:35 AM
chowee21's Avatar
ya, I got the volume and the seeks to work fine, but the mode button is unresponsive
Old 01-27-2010 | 07:49 AM
tCb00b's Avatar
Did you leave the SWI-PS disconnected from the radio while programming it? I had a similar issue on a newer Mini Cooper and found out that the W/R line needs to be left unplugged until you program the SWI-PS.
Old 01-27-2010 | 06:20 PM
chowee21's Avatar
i didnt leave it unplugged, so i guess i'll try it that way, but i dont understand how that will change because i already got the other buttons to work correctly minus the mode button
Old 01-27-2010 | 09:15 PM
cweckel2000's Avatar
I have the same problem with the mode button not working. Up until this point i've just let it go but I'm very interested to see if their is a resolution to this....
Old 01-28-2010 | 03:19 AM
firecracker's Avatar
In for possible results. I have a kenwood dnx6140 and could never figure out how to get the mode button working. I finally gave up and just let it go.
Old 01-31-2010 | 08:43 PM
chowee21's Avatar
I tried to program it with it unplugged from the unit, but it still did not work....
Has anyone else NOT had this problem? Also, i had to purchase my 560 ohm resistor becuz mine was lost, and it is rated at .5 watt, i dont know if that makes a difference or not, but i decided to throw it out there.
theunclesam
09-27-2010 05:12 PM
WhiskeyDrinker
Scion tC 1G ICE & Interior
10-06-2009 05:18 AM
CrazyMPG
08-13-2009 07:49 AM
daredevildoo
09-28-2008 03:19 PM
TheDave1022
177
09-28-2008 07:31 AM
