Both Cig lighters out (the one in the armrest as well) NEED HELP
Old 08-10-2009 | 04:56 AM
icemanscion's Avatar
Default Both Cig lighters out (the one in the armrest as well) NEED HELP
Both of my power outlets (cigarette lighter type) are out. I switched the Cigarette lighter Fuse (Which was bad) and still neither work. Is it another fuse for the one in the armrest? Please help.
Old 08-10-2009 | 04:57 AM
SquallLHeart's Avatar
yes.. they are run on different fuses.
Old 08-10-2009 | 05:03 AM
happen to know which one the other one is?
Old 08-10-2009 | 05:12 AM
probably the "AUX".. though i would have to check the owner's manual..
or.. you can check it yourself.
Old 08-10-2009 | 05:41 AM
shift_fast's Avatar
This happened to me already for about 6 times. I tried all the research and putting lower fuse (from 15, 10, 7.5 amp). But they only work for few days. If you are lucky, they work for about 2 weeks to three weeks max. So what I did is I replaced the fuse for the cig lighter the same fuse (15 amp low profile). Then for the outlet, instead of 15 amp low profile fuse, I upgrade it to 20 amp low profile fuse. So far the fuses never blew ever. It has been a month so far. You can get these fuses at Autozone.
The fuse location is at the driver side, under the steering. Not literally under the steering, but close to where the hatch you open the hood.
Old 08-10-2009 | 05:54 AM
circuits are rated to handle a certain amount of amperage..
overriding that by stupidly placing a higher rated fuse in the circuit than what was meant to be in there..
is frankly not only stupid.. but DANGEROUS.
we're talking about melting stuff and starting fires here.
Old 08-10-2009 | 06:04 AM
jct's Avatar
jct
just be glad they aren't using a .22 gauge bullet as a fuse
Old 08-10-2009 | 07:34 PM
Default 1/2 working
OK so the cigarette lighter still isnt working, the acc lighter in the armrest is. I switched both fuses with the appropriate fuses. Any suggestions / advice?
SouthernCaliTC
09-15-2015 02:58 AM
StxArOne
Scion xA Aero & Exterior
08-29-2015 04:29 PM
JonathonK
08-26-2015 09:30 PM
ShawnMcc
07-12-2015 12:07 AM
RPMxB
07-23-2004 12:32 AM
