Cig lighter outlet doesnt work... ideas?
Old 11-09-2008 | 02:13 AM
TinmanTC's Avatar
Default Cig lighter outlet doesnt work... ideas?
Bought a cell phone charger from ebay and I think it might be the culprit for causing the outlet to fail..
any ideas on how to fix the problem? Simple fuse?
Thanks!
Old 11-09-2008 | 02:17 AM
LBTC's Avatar
check out the 7.5 fuse under the left side of the steering wheel, that might be the problem, just a shorted fuse, i've blown it a couple times when I did my under the dash lights. GL.
Old 11-09-2008 | 02:54 AM
SquallLHeart's Avatar
you blew the fuse.. yea.
Old 11-09-2008 | 04:21 AM
TinmanTC's Avatar
will check it tomorrow thanks!
Old 11-09-2008 | 05:35 AM
O5_TRD_tC's Avatar
+1 for fuse
Old 11-09-2008 | 09:01 AM
krazyscion's Avatar
or something cut ur wires? ebrake?
if not then it must b the fuse
Old 11-10-2008 | 04:04 AM
kskim20's Avatar
idk dude i had this same problem once and replaced the fuse and still nothing...to this day i have tried everything and my cig outlet wont work...good luck!
Old 11-10-2008 | 04:39 AM
jetlounge's Avatar
there are 2 cig lighter fuses...because you have 2 outlets...be sure you checked the right one.
Old 11-10-2008 | 04:59 AM
Tomas's Avatar
Admin Emeritus
Actually, there are three power outlet/cig lighter fuses...
(This is from the '06 owner's manual...)
Old 11-10-2008 | 05:57 PM
kskim20's Avatar
^^^I changed out the one under my steering wheel by my left foot...wheres the other fuse located?
Old 11-10-2008 | 06:04 PM
mcheng08's Avatar
under the hood near the battery
Old 01-06-2009 | 09:21 PM
badmotrfngr's Avatar
The fuse to replace is the #15 not the 7.5 as listed in the other reply. I had the same problem using a cell phone charger with the cig lighter/power outlet inside the armrest and had to replace the fuse. The 15 is right below the 7.5. The fuse chart is a little tough to read.
Old 01-06-2009 | 09:58 PM
^^ because you were using the "power outlet" (located inside the armrest..) vs the "cig" lighter.
Old 01-06-2009 | 10:01 PM
jetlounge's Avatar
maybe you all should just quit smoking
Old 03-18-2009 | 01:24 AM
dgonzalez1968's Avatar
Default Blown Fuses
Did you get this issue fixed? The 15A fuses keep getting blown. I can't connect anything to the Cig lighter nor the Acc adpater below the arm rest.
Thx
Old 03-18-2009 | 01:27 AM
DivisionbyZero's Avatar
Default Re: Blown Fuses
Thx
Are you tapping anything else off of this circuit?
Old 03-18-2009 | 04:01 PM
Not that I know of. I purchased a used '06. I don't have any additional accesories than those factory-installed. Is there a test I can do to find out, or do you think I should try warranty? I'm a little weary of letting them play around with the wiring.
Thanks!!
Nixxie
07-25-2015 06:35 PM
TOOSLOW
07-25-2015 06:19 PM
herbn44
07-24-2015 03:26 PM
JRH13
07-23-2015 04:28 PM
blackpearlTC
07-19-2015 05:55 PM
