Component and Amp suggestions needed...
i have kicker door speakers run to 700 watt 2 channel . 8 loud 6" door speakers running to 1300 watt 2 channel at 2 ohm. loud speaker is def more louder than door speakers. if u want more louder than that. add some horns such as selenium drivers wich will give u piercing sound but that will be stupid loud,
i definitely like em. and i have stretched em to the max and no issues with them (just the tweeters went out, which i've got replacements for). if i could i'd get another set of this series, but couldnt find any when i was looking to replace the rears so ended up with the db models.
make sure tho most of the after market tweeter by it self is 4 ohm. just to be in safe side put a bass blocker on. if its like bullet tweeter or such they already have bass blocker on. wich some people call cross over. when u put those on ur amp actually dont read tweeter and u dont want to blow it out so its helpful when u put bass into door speakers. because mostly it will be jumped off from door speakers.
well invest in equalizer. if u want more control over u will need eq. cross over on amp and radio only can do soo much. plus if u have nice equalizer it will def def clear out the sound. plus u can make it little louder thx to the volume control on eq. get nice 7 band and hifonics amp 100.2 is good amp but still isnt strong enough. find 2 channel amp that will least do about 400 rms. but now is tho u have to c it good. its depends on how amp rated in what volt. most of the amp is rated at 14v. its kind hard to get to full 14v with just stock battery and wiring. no look for the amp that is rated power at 12v
Pro audio would be the route to go
Not noob friendly, though.
If u want LOUD, components are not the way to go.
Something like
http://www.usspeaker.com/faital%20pro%208pr200-1.htm
http://www.parts-express.com/pe/show...number=294-608
Would get stupid loud on 100-200w
Something like
im talking about loud speaker will give him plenty of mid bass. if he put it in full range. tweeter will not give out bass . bass go in to those will blow it. thats why people have bass blocker on it . plus bass blocker will make amp wont read the tweeter so ohm to amp will not change.
corbmonster
01-24-2015 06:13 PM
Jedi_Taboos
35
02-12-2004 04:57 AM
