Detailed writeup on how to change your needles colors! PICS!
Old 08-24-2010 | 10:45 PM
  #221
cyr0n_k0r's Avatar
I'm sure it has been said many times before but I'd like to say that I had my guages swaped by Jeremy in August of 2007 and everything is still working great. I have not had any problems with his work. 3 years and going strong, thanks for a great job.
Old 09-09-2010 | 02:31 AM
  #222
Garage1217's Avatar
Right on man Excellent to hear from my customers!
Old 10-05-2010 | 05:52 PM
  #223
Garage1217's Avatar
BuMp!
Old 10-26-2010 | 03:54 PM
  #224
Garage1217's Avatar
Cooler weather is finally here BUMP!
Old 11-24-2010 | 05:54 PM
  #225
Garage1217's Avatar
Almost turkey day bump! I hope all of your travels are safe and awesome!
Old 01-05-2011 | 06:51 PM
  #226
Garage1217's Avatar
2011 Already BUMP! Hope all of you had an excellent new years!
Old 01-20-2011 | 06:26 PM
  #227
Garage1217's Avatar
Bump!
To note, all colors of all bulbs are back in stock! And of course all other items are in stock and good to go! Browse around our web-store at http://store.garage1217.com/
Old 02-11-2011 | 08:20 AM
  #228
ShaggyMunky's Avatar
I just got my car (2010 model, don't know if that matters) about two weeks ago and I'm really wanting to change out all of the lights on the gauge and HVAC. What I want to do is have the numbers green, the needle green, and the hash marks white. I'm the kind of person that likes to ask a lot of questions just to make sure I have everything right, so please forgive me.
How much green vinyl would I need to purchase to accomplish this?
Also, since the gauge itself has red for the temp and tach and I would be using white LED's, I wouldn't need to get red vinyl correct?
For the LCD's I want to have it reversed with a green background and white numbers. 1) Is this possible? and 2) Would you be able to see that type of combination in the day? 3)Or would it be better to just use green LED's?
For the steering wheel control lights, since I will be doing those green, how many green LED's would I need?
On the HVAC I want to do the temp gauge fade, are there any other resistors that need to be changed?
Here's an example of what I'm thinking of. One with green and white on the LCD the other just with the green LED's.
Old 02-22-2011 | 09:33 PM
  #229
Garage1217's Avatar
Sorry did not see this until now! best bet is to PM me for fastest response as I do not get notification of all posts via email!
Not a prob on that swap...
How much green vinyl would I need to purchase to accomplish this? 1 sheet is plenty
The red is permanent on the gauge faces so no need for red vinyl.
For the LCD's I want to have it reversed with a green background and white numbers. 1) Is this possible? and 2) Would you be able to see that type of combination in the day? 3)Or would it be better to just use green LED's? Sorry that combo is not possible. Light green letters with a dark, dark green background is the way it would be reversed in green.
For the steering wheel control lights, since I will be doing those green, how many green LED's would I need? 3 total for the steering wheel + a steering wheel resistor.
On the HVAC I want to do the temp gauge fade, are there any other resistors that need to be changed? You will need the HVAC / Power IC kit on our site, that is mandatory on the HVAC swap.
Old 03-11-2011 | 06:49 PM
  #230
Garage1217's Avatar
TGIF Bump!
Old 03-29-2011 | 03:22 AM
  #231
Garage1217's Avatar
Monday is OVER WOOHOO BUMP!
Old 05-13-2011 | 12:47 AM
  #232
So I just changed out my center console however the red and blue light where the temp control do not light up very bright I was wondering if there is a particular resistor that I would need to work on to get them going?
Old 06-01-2011 | 04:04 AM
  #233
Garage1217's Avatar
Tuesday Bump! The temp **** is never super bright as the plastic is very thick in that location / have never looked into making it any brighter sorry!
Old 06-01-2011 | 07:38 AM
  #234
I found out the problem. The red LED that I had on there was not allowing for the current to run as strong through both of the LEDs I replaced. Once I switched it out it was all good.
Old 06-01-2011 | 04:50 PM
  #235
Garage1217's Avatar
Right on! Glad you found the issue!
Old 08-06-2011 | 05:33 PM
  #236
Garage1217's Avatar
Saturday BUMP!
Old 08-08-2011 | 06:58 PM
  #237
Mandystc's Avatar
Ok, i have a small question that i probably already know the answer to.... for the stock gauges, are the stock led's orange or is it the faces that have an orange layer in them. im thinkin bout have a purple/white combo done on my gauges and was wondering if all i had to buy was the vinyl or that AND the whites led's. like i said i think i already know the answer to this, i just like to make sure of things as well before i attempt messing with stuff.
Old 08-08-2011 | 07:25 PM
  #238
Garage1217's Avatar
Correct, you need white leds and vinyl. The stock leds are amber
Old 08-27-2011 | 09:35 PM
  #239
Garage1217's Avatar
BUMP~!~
Old 09-20-2011 | 07:37 PM
  #240
Garage1217's Avatar
September BUMP!
