DETERMINATION & PUNISHMENT - New Subwoofer Setup
Originally Posted by STNC
What is EPICenter?
http://www.mobileaudiocontrol.com/pr...49&l1=5249&l2=
"The Epicenter restores bass cut-off by iPodsTM and other MP3 players. Give your subwoofers the juice to go lower and hit harder. The Epicenter uses a patented bass circuit to drive your subwoofers lower, grabbing the attention of every eye on the boulevard."
^ Try it, you'll like it! There's really no way to adequately explain the difference, but it only takes a moment of listening and you'll be convinced. After owning one for about 17yrs now, I can't imagine not using one, it's a "must have" for my systems.
I noticed they changed the spelling (case) on the new units, such that the OP's says "EPICENTER" in all caps, while my older model reads "EPICenter".
What is EPICenter?
Because I have no problem getting low-end out of my iPod.
It sounds fantastic just the way it is.... and I know the difference between what sounds crappy and what sounds good.
Is this meant for iPods that are hooked up using the headphone output or something?
Where do I get one? How much are they?
Here's one on eBay, Buy It Now for $144.
http://cgi.ebay.com/NEW-AUDIO-CONTRO...d=p3286.c0.m14
What quality mp3 files are you guys using?? I don't understand why your iPod is making music sound crappy...
Sure it helps in that situation, but it does sooooo much more for a system. Forget the MP3s, it makes a big difference with top-quality production CDs too.
It analyzes the signal and detects second-order harmonics of missing fundamental frequencies. Then it recreates the fundamental from the harmonic, and add it back in so you don't miss any of the low frequencies. The thing is, the level is user adjustable (remote, so you can control it from the dash), so that even when none of the low frequencies are missing, it can add a HUGE amount of low-end bass to the signal going to your amp. There's also a built-in subsonic filter, so your amp isn't wasting power by producing frequencies your sub can't cleanly produce, effectively giving them even more power in the range where they're most efficient.
So even if you only use the best quality source material, your system can still benefit from an EPICENTER, especially if you're a "bass head". In fact, many people considering more subs and more amp power would likely be surprised to find that adding an EPICENTER is all they need, and it's certainly easier and less expensive than upgrading subs & amps. I should also mention that it's capable of generating enough bass to destroy a sub system, so you have to be careful with the dial, you can easily send your subs into distress (over excursion) by turning it too far.
How easy of an install? Does the rca from the HU go to the epicenter, and then epicenter to amp?
Unique Scionikz
Originally Posted by BZinn1
A second Alpine would sure look better under that plexi.........
I have a Memphis amp hidden under the passenger seat running the components.
Unique Scionikz
You couldn't be expected to know this, as you were probably like 5-10yrs old when it was in production.
They may not now, but they did for a while, so a person should be able to locate one if they really want that type. The in-dash unit had a built-in SPL meter too, with the digital display of the dB right on the front of the half-DIN sized unit.
Originally Posted by Dr_Isotope
They still make the EPIC-160. Too bad we have no place to put it.
