DIY:"lighter" coolant(PICS)
Old 04-26-2007, 03:55 AM
mar10's Avatar
Default DIY:"lighter" coolant(PICS)
alright, so this is my first write up... of a mod i have had for a couple of days but since one of my leds went out i decide to do a write up while i fix it to show everyone...
let me know what you think
IN THIS FORUM YOU WILL LEARN HOW TO: light up your engine coolant holder
what you need:
1.leds(i chose white)
2.some wire
3.some tools(drill, wire stripper, and wrench)
4.about 20mins
5.good music
-okay so first you begin by removing the one bolt that holds the little tank
-then you continue by removing the hose and insert thing(if you notice... i changed my hose from the stock black to the cooler clear... which as you will notice will later also get lit!
-then empty coolant into some container
-next drill some holes into the tank(i used 1/4 bit which made the fit perfect)
-insert the leds into the holes
-i then used some hot glue to secure them in place and to avoid the possibility of any leakage
-connect all the wiring together ofcourse all +with+ and -with-... i wired it up to a switch inside since it is def not something i would like on 24/7
-then be smart and check for wiring errors or just incase any led is faulty and TEST them
-place tank back in place and bolt back on
-use a funnel to put the engine coolant back into the tank
-retest everything and you should have this:
-here is a picture of the clear tube that connects to the radiator i told you about earlier that i also lit up:
-here it is all together:
and here are a few random pics some are my car at a show and a cool lambo
ALRIGHT... so tell me what you guys think? good write up? good mod?
-HOllA Mr1
mar10 is offline
Old 04-26-2007, 03:57 AM
riboflavin's Avatar
cool DIY!!!
riboflavin is offline
Old 04-26-2007, 04:22 AM
Concept in Motion Crew
Dakine's Avatar
WOW!!! Unique i must say. LOVE THE IDEA!!! But i dont think hot glue will last long, i say silicon.
Dakine is offline
Old 04-26-2007, 04:58 AM
Daskid's Avatar
Unique. Big props to you.
Daskid is offline
Old 04-26-2007, 05:02 AM
dibbz's Avatar
yea i was thinking silicone too. but awsome idea!!! looks good too.
dibbz is offline
Old 04-26-2007, 05:04 AM
Big Sky Scion
Jiggaman's Avatar
cool!
but i agree with dakine - silicon would seal the job ALOT better i think! i bet some other colors would be cool lookin with the pink coolant!
nice DIY!
Jiggaman is offline
Old 04-26-2007, 05:12 AM
Team Sushi
fairladyz541's Avatar
Whats the diameter of the clear tubing and did you just pick that up at home depot.
fairladyz541 is offline
Old 04-26-2007, 05:18 AM
mar10's Avatar
thanks for all the reply guys...
tubing? YEP! home depot the diameter is i think either 5/16 or 7/16... double check before purchasing... i will check tommorow morning and get back at ya...
mar10 is offline
Old 04-26-2007, 05:31 AM
Unique Scionikz
KINGxOFxSKA's Avatar
very nice!
KINGxOFxSKA is offline
Old 04-26-2007, 05:50 AM
Resu's Avatar
very cool. I like the unique idea...and could be nice at night when you can't see anything. Props go out to you sir.
Resu is offline
Old 04-26-2007, 12:17 PM
OhioScions
Eppopipe's Avatar
i think ima go do this today
cept i wonder what would happen if i use differnt color leds?
Eppopipe is offline
Old 04-26-2007, 12:20 PM
OhioScions
Eppopipe's Avatar
so did you put a led in the colant tube too?
Eppopipe is offline
Old 04-26-2007, 12:26 PM
BrEaK_AwaY's Avatar
nice job man. if i didnt have MMW billet tanks i would do this
BrEaK_AwaY is offline
Old 04-26-2007, 03:51 PM
Kratos's Avatar
very nice!
Kratos is offline
Old 04-26-2007, 07:04 PM
Viace's Avatar
Really cool its different, good job
Viace is offline
Old 04-26-2007, 07:15 PM
Fsu1dolfan's Avatar
Nice work....i like
Deserves to be a tech article! Keep us updated on stability on the glue and leds
Fsu1dolfan is offline
Old 04-26-2007, 08:03 PM
jay_jay_n's Avatar
OHH DAYM KOOL IDEA thx man i got to do this .. and yeah don't use hot glue i would assume the heat will make it come off.
jay_jay_n is offline
Old 04-26-2007, 08:10 PM
captainlaziness's Avatar
Very interesting, I would've never thought to do that. Good job.
captainlaziness is offline
Old 04-26-2007, 10:12 PM
gizmokat's Avatar
wow! that looks fantastic. Good job
gizmokat is offline
Old 04-27-2007, 01:53 AM
Scionizer07's Avatar
Sweet! Try it with red LEDs so it looks like lava... or maybe just red kool-aid!! Yeah put some silicone on there to seal it up.
Scionizer07 is offline
Quick Reply: DIY:"lighter" coolant(PICS)
