View Poll Results: What do you think about the new mod??
Voters: 117. You may not vote on this poll
Engine Push Start Button Installed!!!!!!!!!!!!!!!!!!!!!!!!!!
#61
explain this "immobilizer system". what is that? I'm guessing the electrics involved in the ignition aren't a simple on/off switch. I noticed on the PDF wiring diagram there's a transponder unit deep within the dash-do our cars use transponder keys? I thought those were only in expensive cars. hmmm. also there's a guy who did it in a crx I found after I posted, check this out:
http://www.crxchaos.co.uk/starter-button.html
granted the car is older but it apparently can be done. that's what I care about
#62
oh and I also just read somewhere about the steering lock mechanism. apparently without the key in the barrel the steering wheel locks. I'm sure the lock can be mechanically removed ? again, security won't be an issue b/c I'm waiting to install a detachable sparco steering wheel.
#63
#64
how does a mass of metal, glass, and plastic, know if someone is "trying to steal it." And of course your car won't start if you put the wrong key in it. That's true for anything that uses a key. My house has an immobilizer then, if I use the wrong key, I can't unlock the door!
I'm confused. But we're clear on the transponder. Will that eliminate the possibility of replacing the barrel with a push button?
#66
The immobilzer means it cannot not be hotwired or have the ignition jammed and turned to start the car. EVEN if you find away to turn the ignition, without the transponder from the key, the car WILL NOT start.
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
TheRedBox
31
12-02-2003 04:53 PM
