Finding the reverse wire
Ok - so I installed my AVIC-D2 a while back and couldn't find the reverse wire. I didn't connect it and things seem to run fine but I've heard the car really needs it to track reversing and keep things where they should be. Does anyone have any good ideas about how to find this wire without going totally nuts on things? Let me know. All the tips I've seen are incorrect, incomplete, or wildly vague.
tc wiring harness
12volts
red (30A), white (25A)
ignition harness
Starter black + ignition harness
Second Starter green + ignition harness
Ignition blue + ignition harness
Second Ignition yellow + ignition harness
Third Ignition N/A
Accessory gray + ignition harness
Second Accessory N/A
Keysense black - ignition harness
Power Lock green to blue - driver kick, 20 pin plug, pin 15
Power Unlock purple to pink (double pulse) - driver kick, 20 pin plug, pin 14
Lock Motor blue to brown 5wi driver kick, gray 7 pin plug, pin 6
Unlock Motor pink to blue 5wi driver kick, gray 7 pin plug, pin 5
Parking Lights+ brown + top of fuse box, 30 pin plug, pin 29
Parking Lights- brown - headlight switch
Hazards orange - hazard switch
Turn Signal(L) yellow + top of fuse box, 30 pin plug, pin 27
Turn Signal(R) green + top of fuse box, 30 pin plug, pin 28
Reverse Light pink + top of fuse box, 14 pin plug, pin 2
Door Trigger orange (D), blue (P) - top of fuse box
Dome Supervision blue - L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin purple - top of fuse box, 30 pin plug, pin 7
Hood Pin N/A
Trunk/Hatch Release orange - driver kick, gry 12 pin plug, pin 12
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black ac data link conn. under dash, pin 9
Wait to start N/A
Brake Wire blue + brake pedal switch
Parking Brake black - parking brake switch
Horn Trigger white - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module
MAKE : SCION | MODEL : TC | YEAR : 2005
add, for audio....
Radio 12v blue + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna orange + radio harness
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- lt. green - blue +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
acc....
LF Window up/dn yellow - pink A driver window switch in door
RF Window up/dn yellow - green A passenger window switch in door
LR Window up/dn N/A
RR Window up/dn N/A
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
12volts
ignition harness
Third Ignition N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
add, for audio....
acc....
LR Window up/dn N/A
RR Window up/dn N/A
https://www.scionlife.com/forums/viewtopic.php?t=138455
?? that's where i went...
it's like a plug on the passenger side... blah... pics should be in the diagrams...
grr.. need a camera.. that'd be better..
NewBox06
02-03-2015 12:36 PM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
