Gauge install problems HELP!!!
Old 03-27-2010 | 05:00 PM
RSTC_120's Avatar
Default Gauge install problems HELP!!!
ok well i installed a triple gauge pod, i have volt, airfuel, boost/vacuum. i have connected the volt meter, that works fine. however im stuck on how to connect the a/f and b/v gauge. i was thinking to hook up the a/f off the o2 sensor but there are 4wires and have no idea where they go. the b/v gauge was going to find a vacuum line but lol there isnt a diagram for the lines so im confused. if anyone could help me out id be appricated. thanks
Old 03-27-2010 | 06:55 PM
05_ScionTC's Avatar
tap the boost gauge off on the brake booster line thats running along the firewall and bout halfway turns into metal. tap it on the right side of that to get a more accurate reading. volt?? imo shoulda got oil press. or temp.
Old 03-27-2010 | 10:02 PM
TheQuietThings's Avatar
is the car boosted? what kind of A/F gauge are you using? wideband or narrowband? Either way, you won't be able to use either of them unless you are using a wideband sensor with a wideband gauge. The tC comes stock with a hybrid 02 sensor that reads up to 3V's, and neither sensor accurate reads 3V.
my06tc
06-25-2015 01:18 AM
ndillon
01-26-2015 05:28 PM
JM Auto Racing
12-19-2014 07:36 PM
mattjk
121
12-22-2004 11:49 AM
TheRedBox
31
12-02-2003 05:53 PM
Quick Reply: Gauge install problems HELP!!!
